choke question
Old Jun 6, 2014 | 02:22 PM
Ken Blythen's Avatar
Ken Blythen
Originally Posted by rustyleerusk
Bad news, discovered the fittings in the carb where the brass connection goes that the fuel filter screws into ar slightly stripped. (got to love previous owners). Temporary fix is epoxy. Assuming I will have to get a whole new carb???
If there is enough metal around the hole, you could helicoil it, or tap it out for an oversize fitting.
Old Jun 6, 2014 | 09:37 PM
LARIAT 85's Avatar
LARIAT 85
Originally Posted by oneowner83
Ahhh, the choke plate still works perfectly via the thermostatic spring, even without the hot air portion. Ask me.....31 years experience!!
I suppose the choke will open without direct heat from the choke tube...eventually. But certainly not "perfectly." It will work a LOT quicker if the heat were routed directly to the spring, as intended. And even quicker still with the electric assist choke cap. Without a source for the hot air to directly heat up the thermostatic spring in the choke cap, the engine will run on a richer mixture for a much longer period of time, wasting gas and causing unnecessary engine wear.
Old Jun 7, 2014 | 01:10 AM
DAWG FAN NO.1's Avatar
DAWG FAN NO.1
i have a 1984 f-150 with a 4.9 300 6cyl choke pull-off wasnt working after engine got hot it would bog down when accelarating or wouldnt crank so i bought a new one i want to make sure all vaccum hoses are in proper place can someone please help
Old Jun 7, 2014 | 11:04 PM
Ken Blythen
DAWG FAN NO.1
It would be best to go to the 80-86 forum page - 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks - Ford Truck Enthusiasts Forums & start a new thread to get the best response.
You could also post a thread in the Inline Six forum - Ford Inline Six, 200, 250, 4.9L / 300 - Ford Truck Enthusiasts Forums
asmith6
May 18, 2016 06:40 AM
Old Coyote
Jun 9, 2012 10:34 AM
E30tdf
Oct 15, 2009 08:31 PM
gearshift101
Nov 29, 2004 08:22 AM
Luke Peterson
1978 - 1996 Big Bronco
Dec 27, 2001 10:02 AM
