Please help asap!!!!!!! Differential problem
Old May 29, 2014 | 09:47 PM
Lawrence Taylor's Avatar
Lawrence Taylor
Trailering
Hi all, I need some help. I have a 98 E350 club wagon xlt with the v-10 and I have some differential issues I need help with. My van was making a clunking noise when switching from reverse to drive and from park to reverse etc..etc. Assumed it was u-joints so went ahead and replaced them and while I was under van, I moved rear tires and saw the pinion gear moving in and out and just had a lot of "slop" in it. Friend told me I could just tighten the nut on the pinion gear but, not sure if he is right or if I need to put new pinion bearings in. Does not howl or grind but I have a long trip coming up and don't want it "blowing up" on me. Any help or advice would be GREATLY appreciated.
Old May 30, 2014 | 07:37 PM
chcknugget's Avatar
chcknugget
Sounds like your pinion bearing is shot... If the nut is that loose the damage has already been done!
snakedoc
19
Mar 3, 2014 02:49 PM
Boba Fett
Dec 26, 2013 08:07 PM
jahollis2380
1978 - 1996 Big Bronco
Dec 15, 2011 07:50 PM
paradiddle
Mar 24, 2008 05:59 PM
Minger
Jan 13, 2007 10:00 AM
