EOT Lower than ECT
Old May 28, 2014 | 07:35 PM
jcalebw's Avatar
jcalebw
EOT Lower than ECT
This is werid... just started doing this a couple of days ago the EOT is 189 and the ECT is 196 is that normal?
Old May 28, 2014 | 07:37 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
That's after driving for a while?
How close are the temps first thing in the morning for ECT, EOT and TFT?
Josh
Old May 28, 2014 | 07:58 PM
jcalebw's Avatar
jcalebw
All the same
Old May 28, 2014 | 08:07 PM
Money-Pit's Avatar
Money-Pit
120 mph breeze through radiator causing excessive cooling?
LOL
Old May 28, 2014 | 08:14 PM
jcalebw's Avatar
jcalebw
Haha thats a different post lol
Old May 28, 2014 | 08:35 PM
jswartz84's Avatar
jswartz84
Just brainstorming, you said it was fully bulletproofed in your other thread. Sounds like you have a cooling system problem, like a broken water pump.
dannyboy950's Avatar
dannyboy950
In the real world this can't actually happen. You would be breaking about half the laws of physics.
You have a biased sensor [out of range] or what you are reading them with is messed up.
The cooling system is designed for the coolant to absorb the heat of the oil and the block. The coolant is then cooled by the air flowing thru the radiator. The air flow absorbs the heat of the coolant.
Old May 28, 2014 | 09:56 PM
jcalebw's Avatar
jcalebw
I know how do you insert a pic its a sct ts thats reading it
Old May 29, 2014 | 05:22 AM
Mcrafty1's Avatar
Mcrafty1
You have to be the luckiest 6.0 owner on the planet!.....
I suspect you are being fed some inaccurate information from your sensors though.
Old May 29, 2014 | 05:33 AM
npccpartsman's Avatar
npccpartsman
By fully bulletproofed do you mean bulletproof oil cooler setup? If that's the case then EOT can easily be lower than ECT.
Old May 29, 2014 | 07:23 AM
69cj's Avatar
69cj
Unplug the sending unit, clean the terminal and plug it back in. Same thing happened to me and it had a high resistance connection at the plug. You should also post the year and all mods, esp. engine related, in your sig. Makes it easier for people to help you.
coolfeet
Oct 17, 2015 10:58 PM
Hotpocket
Jul 16, 2013 07:50 AM
73cntry
Nov 21, 2011 04:27 PM
stelectric
3.8 & 4.2L V6
22
Sep 7, 2007 08:03 PM
explorer96
Jan 31, 2004 07:19 PM
