I6 code332 help
Old May 29, 2014 | 04:30 PM
Fordfr4x4's Avatar
Fordfr4x4
Also abs light goes on sometimes never with check engine light either one or the other that's what led me vacuum side
Old May 29, 2014 | 06:32 PM
rla2005's Avatar
rla2005
I do not think a vacuum issue, Code 332 and your ABS light are related. Let's stick to one issue at a time.
Old May 29, 2014 | 07:12 PM
Fordfr4x4's Avatar
Fordfr4x4
Are related or typo and are not related just curious
Old May 30, 2014 | 08:48 AM
rla2005's Avatar
rla2005
Code 332 is not related to your ABS light
Old May 30, 2014 | 06:40 PM
Fordfr4x4's Avatar
Fordfr4x4
So here's what I found. A few months ago I replaced the canister, before the replacement I had vacuum to egr and codes 332/334. I replaced this and I have code 332 and no vacuum to egr. I switched lines on canister tonight wondering if I messed them up, I now have proper vacuum under all conditions and no code, however the engine acts funny. If I'm going let's say 30 and holding 30 it starts to stumble but if I throttle to gain speed it quickly corrects itself. compression on each cylinder was great plugs wires coil replaced cap checked, wondering why it runs great with a code and everything but egr code but the other way no code but engine acts stupid. Any suggestions as to this
Old Jun 1, 2014 | 07:41 AM
Bad Bad Leroy Brown's Avatar
Bad Bad Leroy Brown
Originally Posted by rla2005
What year truck do you have?
Prior to late '95 to '96 the EGR feedback signal is positional not flow based.
Code 332 is infact a refrence to flow, but is it possible that the positional based system will throw this code if the pcm sees a position that would RESULT in low flow?
Or is there a different code that refrences position in the wording it should throw? Im just saying you may be arguing over nothing.
Old Jun 1, 2014 | 08:18 AM
rla2005's Avatar
rla2005
Or is there a different code that references position in the wording it should throw? Im just saying you may be arguing over nothing.
A truck using EGR Valve Position (EVP) feedback has no way of measuring flow...period. The PCM is expecting a voltage feedback based on how far open the EGR is. You could stick a plug on the bottom of the EGR valve, creating zero flow, and the PCM would be perfectly happy. The same cannot be done on a truck (or car) using DPFE, flow-based, feedback.
In this case the PCM is not sensing a change in EGR position, via the EVP sensor, when it commanded the EGR to open.
All of this is caused by referencing code definitions that are not matched to the year and/or model of vehicle you may be working on.
Old Jun 1, 2014 | 10:26 AM
Bad Bad Leroy Brown
So, there is an older list of code definitions that would be apropriate for this year truck, and would specify a position problem with the EGR? Cool, I need to get one. My Hayes supposedly has codes for apropriate trucks going back to the 80s, but 332 mentions flow so it cant be correct.
Old Jun 1, 2014 | 11:16 AM
Lead Head's Avatar
Lead Head
The codes amount to the same thing, but it's important to know what you're dealing with hardware wise on your truck.
On trucks that use an EGR position sensor, the computer assumes that if the valve is open, gasses are flowing. But the computer has no way of actually checking the flow.
Now, what confuses the issue is that some earlier Ford vehicles actually used a pressure sensor on the EGR valve (2.9L Rangers come to mind), and Ford used the same code for both system types.
Old Jun 1, 2014 | 12:01 PM
Bad Bad Leroy Brown
Confusing indeed,
Just found a link posted by a membet that seems to have proper code descriptions for older position based EGR systems.
"332 (R,M) EGR did not open/respond during test or if memory code, did not open intermittantly"
Cheers
JoePeeper
Jul 11, 2013 12:58 PM
BennyLumpkin
Apr 30, 2013 12:21 PM
rlculver
1997 - 2003 F150
Jul 28, 2009 10:38 PM
cheese5.0
May 26, 2009 08:14 AM
rochs77
1983 - 2012 Ranger & B-Series
May 29, 2007 09:34 AM
