throttle slow decell
Old May 26, 2014 | 11:30 PM
N.W.Ford's Avatar
N.W.Ford
i recently got in a colision with my truck and the only thing wrong is the trottle decells slower with the peddle an it stuck quickly sometimes. help please, thanks
Old May 27, 2014 | 06:33 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Check the accelerator linkage to see if has any broken, bent or binding parts. Could even be a broken motor mount putting things in a bind when engine torques.
Old May 27, 2014 | 06:44 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
X2 on ck the carb linkage for a problem and look for something catching on the bottom side of the air filter. Did you put a chrome one on it? You might need a spacer to raise it back up.
And ck the throttle return spring, you can put one inside another to get a lot more tension.
Does it have an elec choke?
Old May 27, 2014 | 07:57 AM
redroad's Avatar
redroad
If it was front end collision you could have moved the firewall and throttle linkage back slightly without the motor moving back creating a bind .. adjust the rod length accordingly .. Was the hood moved back?
Old May 27, 2014 | 08:58 AM
fmc400's Avatar
fmc400
MSEE
Have you actually opened the hood to investigate yourself?
Old May 27, 2014 | 06:39 PM
N.W.Ford's Avatar
N.W.Ford
yes i have investigated and damages have been assesed and paid for. its a mechanical choke and chrome air cleaner but thats not it. the impact was on the bumper only, pushing on the bottom of the grill.
Old May 30, 2014 | 08:50 PM
N.W.Ford's Avatar
N.W.Ford
i figured out its not throttle linkage causing this, thers good peddle action. maybe tranny?
mastapasta
18
Oct 17, 2016 02:27 PM
beckman
Jun 11, 2014 12:16 AM
Nothing Special
1966 - 1977 Early Broncos
13
Nov 11, 2013 09:53 PM
55fordf100Gramps
Apr 11, 2013 06:20 PM
