White smoke on deceleration
Old May 26, 2014 | 09:33 PM
jac3i's Avatar
jac3i
I have a 2001, F350, 7.3. 800 miles ago I had the turbo pedestal replaced due to a crack in it. My last fillup I filled up with 5% biodiesel and now I have a significant amount of white smoke on deceleration. I am in Amarillo,TX for the night and due in Santa Fe tomorrow. Is this smoke due the biodiesel or is there a more significant problem? I need to get checked out?
Old May 26, 2014 | 10:12 PM
gengine's Avatar
gengine
Is it a coolant type of smoke, or a fuel smoke?
Old May 26, 2014 | 10:37 PM
whitetmw's Avatar
whitetmw
Several things could be causing the white smoke.
Since you're on the road, try the following before starting the engine:
1. Check coolant level. Low coolant could be a number of things, Gasket, Sleeve, etc.
2. Cold Crank it with the key off and listen for a skip. This would be a good indication of compression failure in a cylinder such as a ring, valve, etc. You'll need a piece of wire to jump the solenoid on the starter - or do it the old fashioned way which I am not a fan of.
3. If the other two are negative, after you start it see if the exhaust smells very rich with fuel or a coolant odor (more so than normal for the fuel). This would indicate an injection or fuel delivery problem in general. And sometimes a gasket or O-Ring issue, rare but does sometimes occur.
A Diesel produces white smoke on "incomplete" combustion which could be caused by several things as well. Obstructed fuel delivery to the cylinder or cylinders, malfunctioning injector and so on. Or, just ****ty fuel.
Hopefully, its just the fuel. You could also introduce an additive which may correct or minimize the problem if it is. If you have any of these or an abnormally long cranking time to start, vibration at cold idle, I would be very leery of driving it any distance at all.
Realslowww
Feb 27, 2017 10:16 PM
cricketmowing
Feb 22, 2010 05:09 PM
Dean88
Nov 15, 2008 12:45 AM
dorsetmerv
Sep 23, 2005 07:20 PM
GunNut
Jul 23, 2004 06:57 AM
