Another small problem
Old May 29, 2014 | 05:54 PM
78 & 87 Super Cab's Avatar
78 & 87 Super Cab
Originally Posted by Maltman
haha, weewee hole...yep, I'm that immature.
cant help you on the pump sir
I couldn't resist that
Old May 29, 2014 | 05:58 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
B4A-8591-B .. 223 I-6 Water Pump Repair Kit / Obsolete
Applications: 1954/64 F100/600.
GREEN SALES CO. in Cincinnati OH has 1 = 800-543-4959.
MILLER OBSOLETE PARTS in Binghamton NY has 1 = 607-722-5371.
B6C-8501-D .. 223 I-6 Water Pump / Obsolete
Applications: 1957/64 F100/600.
GREEN SALES CO. has 1.
MILLER OBSOLETE PARTS has 1.
MCDONALD OBSOLETE PARTS CO. in Rockport IN has 1 = 812-359-4965.
ANTIQUE AUTO SUPPLY in Arlington TX has 3 = 817-275-2381.
Old May 30, 2014 | 07:18 AM
hiball3985's Avatar
hiball3985
I wouldn't recommend rebuilding it yourself unless you have a press and the know how. Rebuilt pumps from the autoparts stores or Ebay aren't that expensive and will save you the headaches.
Old May 30, 2014 | 05:29 PM
78 & 87 Super Cab
Still puzzles Me why it started doing this, after I put the new antifreeze back in. It had antifreeze in it when I drained it,that seep hole was dry
Old May 30, 2014 | 06:31 PM
spurredon's Avatar
spurredon
If this engine had been sitting, it may have been leaking before but with no action it dried up in that area. Now you have fresh stuff in there it found it's way out. At any rate, good to find now tan later. I got a water pump from NAPA the was fine.
NAPA AUTO PARTS
not that great a pic.
Old May 30, 2014 | 08:49 PM
Maltman's Avatar
Maltman
wow! only $40 plus a $6.18 core charge at my local napa...
Old Jun 4, 2014 | 08:08 AM
78 & 87 Super Cab
Picked up the new pump, $38.99 at My local NAPA, and they had one on the shelf! Now, when I put new bolts in, do I put any sealer on the threads?
Old Jun 4, 2014 | 10:32 AM
hiball3985's Avatar
hiball3985
I don't recall if any of the bolt holes go into the water jacket, if yes, then sealer would be good. If they are blind holes a little anti-seize would be better.
Old Jun 4, 2014 | 10:53 AM
78 & 87 Super Cab
One on the drivers side apparently did, as when I removed it, antifreeze poured out. I stuck a nail into each hole, they were blind ones
Old Jun 4, 2014 | 05:45 PM
78 & 87 Super Cab
Well, reman pump is on, and it does not leak now, But I made a boo-boo. Like a moron I put the fan spacer on the wrong side of the pulley, see pic Whooooooooooooops!
Old Jun 4, 2014 | 06:27 PM
hiball3985's Avatar
hiball3985
Maybe pictures before taking things apart would help
Old Jun 5, 2014 | 09:21 AM
mgargiullo's Avatar
mgargiullo
I'm impressed that the belts on.
Old Jun 5, 2014 | 01:49 PM
  #28
78 & 87 Super Cab
I had it on right when the old pump was still on, simple brain fart
Was not tightened up
garydmundy
Apr 22, 2017 03:45 PM
alanc77
Jan 24, 2011 09:44 PM
SMACUSTOMS
Nov 21, 2005 10:15 PM
1996F250PSDLB
Dec 17, 2004 10:11 PM
