Another small problem
Old May 26, 2014 | 05:43 PM
78 & 87 Super Cab's Avatar
78 & 87 Super Cab
I filled up My '59 F100 with anti freeze today, and and when I went out later to see if I needed to add more, I noticed a very small drip, and this small puddle, on the timing cover ,see pic below. It appeared to have had a timing cover gasket replacement at some point, where could this be coming from? Could I possibly have the thermostat gasket on wrong, I stuck it to the block, then the thermostat housing,and thermostat
Old May 26, 2014 | 07:24 PM
spurredon's Avatar
spurredon
Hard to tell where you are with the pic so close. Is that the water pump shaft to the left of the view?
Old May 27, 2014 | 07:21 AM
78 & 87 Super Cab
Yes, I'm looking down, between the water pump housing, and generator.
It had coolant in it when I got it, and wasn't leaking.
When I put the new thermostat in, I stuck the gasket to the head,then bolted the thermostat,and housing up. I am wondering, if the gasket should be stuck to the thermostat housing,to keep the thermostat in place?
Old May 27, 2014 | 07:34 AM
hiball3985's Avatar
hiball3985
The thermostat goes into the recess in the housing, then the gasket on top of it, then bolt to intake manifold ( V8's ) or head ( 6 cylinders ). The thermostat may have slipped and is pinched between the housing and manifold or head causing it not to seal.
Old May 27, 2014 | 11:50 AM
Maltman's Avatar
Maltman
I spent a lil extra time cleaning both surfaces really well
Old May 27, 2014 | 12:18 PM
78 & 87 Super Cab
Ahhh, I had a feeling I did it wrong, will correct it, thanks!
I did, the surfaces were very clean
Old May 27, 2014 | 09:07 PM
economan's Avatar
economan
An old timey trick to get the thermostat to stay proper in place is to tie a little piece of thread to it to hold it up until you get everything to seat proper and snug up the bolts.
this is of coarse b4 the time of peel & stick self adheasive gaskets.
Speaking of old timey...remember when thread meant just that not this thing you are currently looking at on this tv screeney thing here
mikie
near Ottawa Canada
58 m100 panel 64 econoline p/u
Old May 27, 2014 | 11:45 PM
78 & 87 Super Cab
mikie
near Ottawa Canada
I'll try that, thanks!
And yes, thread sure had a different meaning back then
Old May 28, 2014 | 07:52 PM
spurredon's Avatar
spurredon
mikie
near Ottawa Canada
That's a good tip, I have always used a little gaset sealer, enough to hold the thermostat is place when installing. Never thought of needle and thread!
Old May 28, 2014 | 08:03 PM
hiball3985's Avatar
hiball3985
I usually use a few dabs of grease to hold it in place, my sewing skills suck
Old May 29, 2014 | 01:06 PM
78 & 87 Super Cab
Well, put things back together, the right way, and soon as I had it nice and full, (to the right level). I looked down,and saw that same little puddle had formed again. What in the heck is happening? It is not going down at all, and had not been leaking before. Should I just wait til I get ready to fire it up,and dump some stop leak in it? I made sure all gasket surfaces were clean and smooth first
Old May 29, 2014 | 02:19 PM
hiball3985's Avatar
hiball3985
I wouldn't recommend stop leak for anything but an extreme emergency to get home. You can't fix it until you find the problem, where is it leaking? Dry everything off and start watching were it is coming from, use a small mirror to see underneath places you can't see.
Old May 29, 2014 | 02:56 PM
78 & 87 Super Cab
I'll have to remove the fan and pulley before I can look. I honestly don't know where it is coming from, it was not leaking when I took things apart for cleaning and painting
Old May 29, 2014 | 05:42 PM
78 & 87 Super Cab
And, I found the cause................. Here is a pic, looking up at the bottom of the water pump. Yep, it's coming from the weewee hole. Are these pumps rebuildable? That would save some Me some coin if so
Old May 29, 2014 | 05:52 PM
Maltman's Avatar
Maltman
haha, weewee hole...yep, I'm that immature.
cant help you on the pump sir
