Aerostar Ford Aerostar
Upgrading charging cable is necessity
Old May 24, 2014 | 08:03 PM
KhanTyranitar's Avatar
KhanTyranitar
When you convert to a higher than stock output 3G alternator, running a heavier gauge charging cable is not optional. The higher output will fry the fusible link. Run at least a 4 gauge wire, preferably with a high amperage fuse (you want it about the same rating as the alternator you are using.
Old May 26, 2014 | 10:41 AM
99f350sd's Avatar
99f350sd
For sure.. I did that in my truck..
Old May 26, 2014 | 07:04 PM
xlt4wd90's Avatar
xlt4wd90
I was thinking that even if you DON'T upgrade your alternator, it's a good idea to upgrade the wires. The stock wires that Ford (and it seems most manufacturers) uses seem just adequate for their purposes.
BLDTruth
28
Mar 19, 2018 08:20 AM
kbarbee95
Jul 9, 2015 03:10 PM
matttaubert
Mar 2, 2008 09:41 PM
tdg038
Electrical Systems/Wiring
Mar 26, 2005 11:09 AM
