My 400 build
Old May 24, 2014 | 10:47 AM
LStoneberg's Avatar
LStoneberg
My 400 build
Well, I got my 400 out of the truck and disassembled. The bearings are totally shot, lots of copper showing, pitting, and pretty deep grooves. I'm concerned about the crank grind. I think I know where the cause was: #8 piston skirt was galled to the max + big groove of material gone and stuck on cylinder wall. Causes and rebuild concerns? I plan to bore block .030. My guess is the usual oil starved 5th journal. Thanks.
Old May 24, 2014 | 03:39 PM
mark a.'s Avatar
mark a.
" My guess is the usual oil starved 5th journal " Don't know where you heard of such a thing but there is nothing usual about #5 starving for oil. I can tell you that the blocks main bores are more than likely out of alignment and roundness so plan on getting it align bored or align honed. Get a set of TMI's pistons. They will be within reach of getting the pistons to a zero deck height with minimal decking, get the rods resized with a good set of bolts, plan on balancing it too. Get a good set of mics and a bore gauge reading in .0001" and set the bearing clearances with them and then you will have a bullit proof botom end.
Old May 24, 2014 | 08:10 PM
LStoneberg's Avatar
LStoneberg
Thanks Mark and we are thinking alike. I have a very good machine shop nearby that will do a fine job. I also plan to do the oil mods and to get Tim's build kit. I'll try to get some pictures posted soon.
slaymaker40
May 23, 2015 05:04 AM
wyoming4x4
106
Jun 11, 2012 10:27 PM
therifleman556
17
Nov 1, 2008 05:43 PM
f-4x4
Jul 25, 2005 08:47 PM
77_F150_4x4
Feb 28, 2005 02:16 AM
