77 351M issues
Old Jun 1, 2014 | 06:18 PM
RCrawler's Avatar
RCrawler
77 351M issues
I've had this 77 F150 for 15 years and have always dealt with a low power issue, but have never really investigated it. After my father in law caught it on fire and burned most of the vacuum lines on the engine, I decided to get rid of it all and simplify with an alum intake and 4 bbl (1406 Edelbrock) It also has a new distributor.
It idles fine and runs decent enough to run down the road. But any time you step on the throttle, it bogs and backfires through the carb when the accel pump hits. It completely falls on its face past that with any throttle input. I would chock it up to carb tuning, except that it did the same thing with the stock 2bbl.
Compression is between 110-120 lbs on all.
I initially set the ignition timing to 10* which gave me total of 45* all in. Vacuum reading was around 15" and bouncing a little at idle.
I played with timing and could get the vacuum to 17, but it took 35* of initial timing to get there. Ironically, the backfire and the bogging went away, at least with no load on it.
I'm suspecting maybe the cam timing is off or the chain has slipped.
Any issues with the ring turning on the balancer?
Just looking for a little feedback before I pull it apart.
Old Jun 2, 2014 | 01:32 PM
85e150's Avatar
85e150
If you pull it apart, are you going to rebuild it?
As a 351m or a 400?
Lots of threads here on building a proper 400.
There are no easily available pistons for the 351m that will bring the compression up. A cam change will help, but it will still be weak and eat more gas than it should.
Old Jun 2, 2014 | 06:18 PM
RCrawler's Avatar
RCrawler
If I do need to go in that far, it will be a 400 when I'm done. I have a spare 400 crank and another block to work with.
Unfortunately for me, I'm a little short of money to build one the way that I want. So, I'm trying to just make the 351 work for awhile. If I just have to swap out the timing set, that's pretty simple and cheap.
Derf47
17
Sep 18, 2016 11:01 AM
derbydad276
15
Jan 11, 2014 11:06 AM
mojo645
Dec 30, 2009 01:51 PM
jamie_lind2006
Jul 15, 2006 06:05 PM
barbecuejones
Jul 21, 2003 03:29 PM
