Problem with bogging out and no power
Old May 23, 2014 | 01:14 PM
Esechler's Avatar
Esechler
Alright so i am going try to explain this as best as possible. My truck idles really rough and has no power. Super sluggish and then all of a sudden it just gets up and goes. Then it gets supper sluggish again. It runs fine until it heats up to operating temp. I got tps code which is 121 i believe. So i changed the throtle position sensor. Still doing the same thing. Then i thought it was the egr. Changed the egr solinoid. Still nothing. Someone told me maybe its your map sensor. So i unplugged it. Runs better but still kind of ****ty. But it is not sluggish no more. So my question is do you think it is the map sensor?
Old May 23, 2014 | 04:38 PM
Conanski's Avatar
Conanski
Did you clear codes after changing sensors? If not give that a try and pull codes again after a couple days to see what comes back. Also check fuel pressure and the FPR for leaks. Are there any exhaust leaks?
Old May 24, 2014 | 09:57 AM
Esechler's Avatar
Esechler
I am sorry i meant MAF sensor. Not MAP
Old May 24, 2014 | 09:14 PM
xkpsanit's Avatar
xkpsanit
Upper to lower intake gasket?? They are junk from the get go
Taylor815
17
May 19, 2017 09:32 PM
ejs05f350
Feb 2, 2011 03:19 PM
fjerstadt
Jun 3, 2010 08:12 PM
frankyford
Jul 31, 2009 11:04 AM
BJScott1986
Jan 22, 2005 11:00 PM
