I replaced a very worn M5R2 1-2 shift fork today. In the process, several small parts fell out.
1)spring
2)oblong detent bearing
3)round bearing
4)small solid pin
I placed the spring in the top cover and then the round ball bearing. I placed the oblong detent bearing between the shift forks. However, I have no idea where to place the small solid pin.
Help!
i have the same problem my m5r2 top plate is at the shop right now been there a few weeks to get new forks . ut they seem unable to get the pins and spring detent kit they need to rebuild the top plate . can u point me in the right direction to get the parts or a possable complet rebuld kit for my top plate plz and thank you
