No rear reverse lights
Old May 20, 2014 | 08:50 PM
JRS2's Avatar
JRS2
And it is not the bulbs, mine is the mazda 5 spd, suggestions on fittings that I may have over looked ? Obviously I need to check wiring diagram and or fuses and relays ....
Old May 20, 2014 | 08:52 PM
Truck Guy99's Avatar
Truck Guy99
It's mostly likely shorted or a fuse is blown. Put a voltmeter on it and see if you have power. If not, trace it all the way back until you get something. Also check fuses before you go throwing parts.
Old May 21, 2014 | 09:15 AM
thewestie's Avatar
thewestie
When I lost reverse light it was a fuse under the hood.
pete/ny
16
Apr 24, 2023 09:26 AM
skooch
Jan 19, 2013 11:43 AM
myakkacracka
Oct 15, 2008 06:10 PM
97F250LD
1997 - 2003 F150
Apr 18, 2006 12:43 AM
flyinfeathers
Jan 16, 2002 07:18 PM
