Sponsored by: Real Truck
REVERSE LIGHTS
Old Jan 1, 2002 | 09:01 PM
flyinfeathers's Avatar
flyinfeathers
REVERSE LIGHTS
Old Jan 13, 2002 | 06:47 PM
ep's Avatar
ep
REVERSE LIGHTS
Anyone had problems with reverse lights, my 99 F250SD has both out.
Old Jan 13, 2002 | 08:30 PM
Monsta's Avatar
Monsta
Sit. Stay.
REVERSE LIGHTS
I take it you already tried replacing the bulbs to no avail. So did you check your fuse? (#28 10A fuse) The trouble could be coming from the digital sensor. I would also check the grounds and connections around the lights and harness. Reply back for further assistance.
Old Jan 14, 2002 | 07:30 PM
Twinbulls's Avatar
Twinbulls
REVERSE LIGHTS
If its not the lights or the fuse check the reverse relay on the tranny.On wifes it went twice,but first I checked the lights and the fuse to no avil.I just followed the reverse light trail.
And as monsta said check all the grounds..
Tim
Old Jan 14, 2002 | 07:44 PM
Monsta's Avatar
Monsta
Sit. Stay.
REVERSE LIGHTS
On an old standard I had the switch was right on hte outside of the tranny. Real easy to service (and get screwed up). Is it hangin' on the outside of the 4R100 also?
Old Jan 15, 2002 | 06:50 AM
Twinbulls's Avatar
Twinbulls
REVERSE LIGHTS
Yes its hanging on the drivers side,two bolts holding it on and a bunch of wires that plug in to it.
Old Jan 15, 2002 | 12:10 PM
ep's Avatar
ep
REVERSE LIGHTS
Thanks guys, I thought it might be the relay, now that I have the location I'll try messin with it!
Old Jan 15, 2002 | 12:46 PM
Twinbulls's Avatar
Twinbulls
REVERSE LIGHTS
Glad we can help, just check the plug and if that looks good than replace it(the relay)We are lucky that our trucks sit so high its easy to get under them to tinker.
Good luck
Tim
Old Jan 16, 2002 | 07:18 PM
ep's Avatar
ep
REVERSE LIGHTS
Especially if your recovering from back surgury!
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
