Sponsored by: Real Truck
Reverse lights stuck on
Old Jan 19, 2013 | 11:43 AM
skooch's Avatar
skooch
2006 F350 6.8 reverse lights are staying on with truck shut off. I pulled the fuse for the reverse lights and they are still on. Doesn't make sense.
Seems like it back feeding from somewhere. I took a voltage reading at the reverse light pin on the 7 pin trailer connector and its showing a little over 10 volts and the battery is fully charged showing 12.5 volts.
I guess the PCM triggers the relay to activate the reverse lights. But wouldn't pulling the fuse kill the power?
It must be shorted to +12 somewhere after the fuse.
Any ideas? Maybe a wiring diagram if possible?
Thanks
Dan
Nubs15
Feb 16, 2018 10:23 AM
beefey
Nov 25, 2017 05:06 AM
AMEC Electric LLC
6.7L Power Stroke Diesel
May 16, 2011 09:28 PM
Diff Whack Daddy
Dec 2, 2003 10:19 PM
flyinfeathers
Jan 16, 2002 07:18 PM
