every single Ford from 90's until mid 2000's that had Cruise Control had a version of this switch.
if you don't have the update, get it done! you can tell it's done if there is a fuse between the switch and the wiring harness
I have a 2005 6.8L, and as soon as I saw this thread, I did run outside and look. I didn't see the jumper. I called my local Ford dealer where I've purchased a number of other vehicles, but not this one. I gave them the VIN, and the service rep said the recall is shown as complete. When I asked why I didn't see the jumper, he said it wouldn't be easy to see, and that it looks like it's part of the original harness. How worried should I be?
According to Ford Motor Co. website here is the list of the FIRST set affected vehicles. The Recall number is 95S28 I even left the cars listed in case you need to have them checked. "MY" stands for Model Year
1992-1998 Crown Victoria / Grand Marquis _ 1992 MY built after February4,1992
1998 MY w/o Traction Assist built from Job #1 through October 31, 1997
1992-1998 Town Car _ 1992 MY built after November 4, 1991
1993-1998 Mark VIII
1993-1995 Taurus SHO A/T
1994 Capri
1998-2002 Ranger Non-FX4 vehicles built prior to May 2, 2002
1998-2001 Explorer/Mountaineer
2001-2002 Explorer Sport & Sport Trac
1995-2002 F-53 Motorhome
1993-1996 Bronco
1993-2003 All F-Series Under 8500 GVW Built prior to October 31, 2002-and 2004 F-150 Lightning
1993-2003 F-Series Over 8500 GVW (All plants except Cuautitlan) Built prior to November 4, 2002
1994-2003 F-Series Over 8500 GVW (Cuautitlan built only) Built prior to January 7, 2003
1997-2002 Expedition
1998-2002 Navigator
2002-2003 Blackwood
1992-2003 E-150/250/350 Built prior to January 1, 2003
1996-2003 E-450 Built prior to January 1, 2003
2002-2003 E-550
2000-2003 Excursion Built prior to November 4, 2002
Note: Diesel engine equipped vehicles are not affected
Reason: corrected
Then a SECOND Recall came out later. Recall # 09S09
AFFECTED VEHICLE APPLICATIONS:
Year Model Notes
1995 Windstar • Vehicles with speed control
1996-2003 Windstar
• Vehicles with and without speed control
• Built through October 24, 2002
1993-1997 1999-2003 F-Series over 8500 GVW (7.3L diesel only) • Vehicles with speed control
2000-2003 Excursion (7.3L diesel only) • Vehicles with speed control
1995-1997 Explorer • Vehicles with speed control
1998-2001 Explorer
• All body styles except postal vehicles
• Vehicles without speed control
2002 Explorer
• All vehicles except those with Interactive
Vehicle Dynamics (IVD) option
1997 Mountaineer • Vehicles with speed control
2002 Mountaineer
1994 F-53 Motorhome • Vehicles with speed control
1992-2002 E-Series (7.3L diesel only) • Vehicles with and without speed control
2003 E-350/450 (7.3L diesel only)
• Built through January 9, 2003
2003 E-550 (7.3L diesel only) • Vehicles with and without speed control
1992-2002 E-Series (gasoline only) • Vehicles without speed control
2003
E-150/250/350/450 (gasoline only)
• Built through December 31, 2002
2003 E-550 (gasoline only) • Vehicles without speed control
1995-1997 Ranger
• Non-Electric
2001-2002 Ranger
• Non-Electric
2002 Ranger
• Non-FX4 vehicles with speed control
• Built from May 2, 2002 through Job Last
• Non-Electric
2003 Ranger
• Built through December 5, 2002
• Non-Electric
NOTE: All assembly plants are affected.
Now I'm even more confused. Is the 2005 not included in the recall? I don't see it listed, and can't find reference on a couple of other sites I found while searching.
Pretty sure (not at work today to recheck) that it stops at most 2003 models with the exception of the 2004 F150 Heritage & Lighting cause they are old body style.
Best way to be sure is to call a Ford dealer with your vin number and have them check it for any recalls.
They will still do this recall, right? Or can I get the harness somewhere to do myself?
Recalls do not have an end date.
Until a vehicle VIN has been entered into Ford's Online Automotive Service Information System (OASIS) as the recall being completed, the recall for that vehicle will remain active.
Ford is the only place I know of that you can get the harness. It's free, so why would you want to buy it someplace else?
I assume he doesn't totally understand how a recall works and just wants to stay on the safe side Take that beast to the stealership and get it done fo free yo!
Ford dealerships will only change the switch or add the harness for FREE if your vehicle is on the recall list. If your vehicle is not on the list you can still have the switch replaced at your expense. Most use the same switch as the recall but not all. I'm not 100% sure if the harness will work on all vehicles.
That looks like a 6.0 to me, so not sure if the switch is the issue.
Also, The 6.0L has hydroboost which is different brake system than a gas engine and uses a different switch. On another note. I'm not sure if the master cylinder was taken off or melted according to the picture. but its gone.
That has nothing to do with it. The 7.3L PSD has hydroboost braking too.
The recall has nothing to do with the type of braking system a vehicle has.
"Ford’s investigation found that brake fluid may leak through the speed control deactivation switch into the speed control system electrical components, potentially corroding them. In rare cases, the corrosion in the electrical components can lead to increasing resistance and higher electrical current flow through the system. Together, these conditions could lead to overheating and, possibly, a fire at the switch. This system interaction is the result of the close proximity and orientation of the speed control components in the recalled vehicles."
"To address this issue, Ford will install a fused wiring harness between the speed control deactivation switch and the speed control mechanism of the affected vehicles. This will act as a circuit breaker, eliminating the electrical current to the switch in the rare event of increased current flow through the switch."
