1982 F150 Bull Bar
1982 F150 Bull Bar
I've seen a few photos of trucks on here that has a chrome or stainless bull bar up front that uses the two front bumper bolt mounts to mount it.
Who makes this and where can i get one?
I have been searching online for the past few days and cant find anything for the 1980 - 86 F150 trucks.
I might have to. I had hoped I could get a set already made ready to go, would be cheaper in the long run. if I had some made I would most likely go with either polished stainless or plain steel and have it chromed. I really like the style shown in the photo and if thats all that is commercially available I would go with thoses.
Im going to revive this to ask a question I have.
Does anyone have the dimensions of one of these bars? If not what about just the dimensions of the two horizontal tubes?
I will be making patterns soon to take to a welder I know to fabricate one for mine but not sure what size the tubing was used.
Correct. I will use it as a starting point then make changes. I'm thinking about the mounting tab for them to put a floor on the bottom of it for strength as well as for mounting a pair of those two bolt tow hooks.
Just a FYI. The design you are looking at is called PUSH bar. A BULL bar is one piece of pipe that comes up, across and back down. And typically has "skid plate" mounted too. Like this
Raptor Series bull bar
This is a bullbar
http://www.tuffbullbars.com/uploads/...0_RANGE_01.pdf
You guys are funny that's a nudge bar,
This is a bullbar
This is a bullbar
This is a bullbar
This is a bullbar
