Sponsored by: Auxito
charging problem
Old May 19, 2014 | 05:17 PM
TexasCoastie's Avatar
TexasCoastie
charging problem
Hello,
My alternator went out last week. I installed a new alternator, battery and serpentine belt. However, the battery is still dying. So far I checked the continuity on the fusible link and it appears to be good. I also cheched fuse number 11 which provides power to the voltage regulator. The fuse is not blown. The voltage at the battery while it is running is less than 12 volts and it drops the longer it runs. Any body run into this issue. I also have codes b1318, b1932, c 1226, and c1284.
Thanks for any and all assistance,
Robert
Old May 19, 2014 | 09:59 PM
Bluegrass 7's Avatar
Bluegrass 7
First thing is the battery is not being charged.
Have to solve this first.
Is the dash charge lamp on?
If yes the alternator is not outputting. The alternator is either faulty or the plugup has an issue, harness, ignition switch etc..
For the codes you needed to look them up to get any benefit from what they tell you.
The B1318 just confirms the low voltage detected at the 4wd module.
B1932 says driver air bag circuit is open.
C1226 ABS brake circuit short to ground.
C1284 Oil pressure switch failure.
I almost sounds like you have harness damage at some location like from an accident or fire etc..
The low voltage codes likely will go away when the alternator is charging again, but the rest are a question waiting to be answered by what you find.
You have some looking around to do to see what's going on.
Good luck.
Old May 19, 2014 | 10:45 PM
TexasCoastie
Bluegrass 7,
No the charging lamp is not on. It came on when the alternator failed. After replacing the alternator the light went out.
Old May 19, 2014 | 11:41 PM
Bluegrass 7
What do you see with a voltmeter across the battery right after starting?
It must rise to about 15 volts +/- then taper down as the battery recovers it's charge.
If you don't see this action, go back to the alternator terminal and make a reading for level.
If not the lead from the alternator is open at some point.
Check the big 175 amp fuse link, cables etc.
Are you sure the cables are back on correctly?
There is nothing more to the circuit.
To see this, look in a HAYNES manual page 12-17.
Good luck.
Old May 19, 2014 | 11:58 PM
TexasCoastie
I get a reading of 12 or less. I checked the voltage at the battery terminals and the back of the alternator and got the same reading.
Old May 20, 2014 | 06:50 AM
KhanTyranitar's Avatar
KhanTyranitar
If your alternator fried, chances are your battery is toast too. Its a cause effect problem, a bad alternator can damage the battery, and the damaged battery can kill your new alternator.
Old May 20, 2014 | 08:31 AM
acogoff's Avatar
acogoff
Take the alternator back to the place of purchase and have them test it on the bench, may be a bad one.
Old May 20, 2014 | 02:54 PM
vaper's Avatar
vaper
Sorry, reread your post, my comment was of no help
Old May 20, 2014 | 04:56 PM
steve(ill)'s Avatar
steve(ill)
alternator should be putting out almost 15 volts. If it does not, then check wires and have alter tested by seller.
Bubba Jones
1978 - 1996 Big Bronco
Sep 17, 2012 12:25 PM
99Ranger43k
1983 - 2012 Ranger & B-Series
Nov 28, 2010 10:07 AM
donaldm
17
Jul 13, 2009 10:50 AM
r0n1n
Electrical Systems/Wiring
Jun 27, 2009 08:53 AM
myke
1997 - 2003 F150
Feb 26, 2006 05:13 PM
