one good thing about the bullet proof oil cooler is you will never get oil in your coolant again.. that's why I went with it...
Unless they got cheaper you pay for that piece of mind. The international cooler is not a bad design. Infact it is incredibly efficient design that both cools the oil and regulate temps. Causes quick coolat warm up etc. The only pitfall is debris from the coolant and casting of the engine parts. The cooler fails from being fatigued from over heating and other issues veru seldom do the oil coolers just fail with out other issues causing the problem
Page 1 has an oil cooler kit and the fuel pressure regulator kit. Page 2 has the upgraded STC kit.
These guys saved me over $50 more then Autonation.
I was looking at that page, it shows an upgrade kit for the 03 and early 04 models and has updated standpipes and dummy plugs. My 03 has the straight rails not the wavy. We're there any 03 or early 04 models with wavy rails? I thought they all had the stainless flex line with the straight rail.
Should I be worried about water in my oil? Where else should I look. Btw Parts list so far stc update ,dummy plugs and stand pipes, oil cooler, intake gaskets, blue spring.
