1966 - 1977 Early Broncos
fuel injection ???
Old Jul 12, 2003 | 01:05 AM
RCrawler's Avatar
RCrawler
fuel injection ???
the 86 crown vic oil pan looks identical to the stock 77. is it worth it to swap out?
With a lift kit and the Dana 44, it will work. But with the larger 60, you may run into clearance problems when the suspension is compressed. There are some advantages. Since the Bronco dipstick is in the pan, and the later model engines have a provision in the block, you will have to block off one or the other. The Bronco pans are notorious for leaking around where the dipstick boss is riveted to the pan. If you try to use the late model diptick with the Bronco pan, it will not go in because the pan is made slightly different.
with exception of the MAP,EGR reg.,and EGR valve i'm guessing that i can block off any vacuum ports that will no longer be used. does this sound like a good idea?
You also need vacuum to the fuel pressure regulator. But thats about it.
where is the best source to supply vacuum to the needed sensors?
You mean a vacuum source? If it is a standard Mustang style intake, all of the connections you need are on the rear of the upper intake underneath the plenum.
Jason
Old Jul 28, 2003 | 10:27 AM
Apache64's Avatar
Apache64
fuel injection ???
does anyone have the pinouts for the ford ecu 1987 sfi
Old Jul 28, 2003 | 10:08 PM
Apache64's Avatar
Apache64
Talking fuel injection ???
okay this is what i got 1980 F150 , I put in a 1987 5.o sefi out of a t-bird still have some wiring isues need help! can find a pinout for the ecu, i;m looking for the wires for the fuel pump relay, a couple of other wires i am still trying to find in the scematics, havent been able to get the alt charging either, still working on it 4 days so far
Old Jul 31, 2003 | 11:45 PM
Apache64's Avatar
Apache64
fuel injection ???
well got it done! here the pinout for a 1987 ford 5.0 sefi
1 blk/org hot in run/start/eec relay hotin run/start
3 dk grn/wht to veh speed control
4 dk grn/yel res./ignition coil
6 org/yel ground
7 lt grn/yel eng temp sensor
8 pnk/blk fuel pump relay/fuel pump
10 pink/lt blu to a/c
11 lt grn/blk air div. sol
12 brn/yel injector#3
13 brn/lt blu injector#4
14 tan/lt blu injector#5
15 lt grn injector#6
16 dk blu tfi ignition module
17 yel/blk to vip conn.
20 blk ground
21 wht/blu idle speed cont.sol./diode
22 tan/lt grn fuel pump relay
25 lt grn/ppl air charge temp. sensor
26 org/wht egr valve position center/throttle position sensor
27 brn/lt grn egr valve position center
29 dk grn/ppl r. heated oxygen sensor gray/yel leads to hot in run
30 brn/wht to starting and charging system
31 gry/yel can.purge sol.
33 dk grn egr vac.reg. sol.
34 lt blu/pnk to electronic cluster
36 yel/lt grn short plug/tfi ignition module
37 blk/yel eec power relay tied to 57
40 blk/lt grn leads to solid blk wire to ???????
42 tan/org injector#7
43 dk blu/lt grn l.heated oxygen sensor gry/yel leads to hot run
45 dk blu/lt grn manifold absolute pressure sensor
46 blk/wht sensor grounds
47 dk grn/lt grn tps
48 wht/red to vip conn.
49 org ground
51 wht/red air bypass sol.
52 lt blu injector#8
54 org/lt blu to a/c heating system
56 blk/org tfi ignition module
57 blk/yel eec power relay
58 tan injector#1
59 white injector#2
60 blk/lt grn leads to solid blk wire to ???????
I hope this helps my son traced these wires out for me , I could have not done it without him!!!!
jvmcc
Jun 14, 2016 03:47 PM
peka
Apr 6, 2016 10:03 PM
Greg5OH
Jan 29, 2013 07:36 AM
kamikazi117
May 3, 2011 12:37 PM
MikeMcCasland
Mar 21, 2009 08:25 AM
