2004 excursion window issue
Old May 15, 2014 | 02:55 PM
TYZ78F150's Avatar
TYZ78F150
My right rear window works when it wants to. I changed the master switch, didnt fix it. So I swapped the other back door switch and still nothing. Now when it does work, I only have down,no up. I removed the panel and ran 12v right to the window motor and it functions beautifully up and down. I'm stumped!
Old May 15, 2014 | 03:01 PM
BassFantasizer's Avatar
BassFantasizer
Sounds like a broken wire.
Old May 15, 2014 | 04:02 PM
lunatech's Avatar
lunatech
I would start with a good wire diagram. The Haynes manual for my 2002 has a pretty good window switch diagram in it. I would start at the master switch (even though you just replaced it) and make sure you have power going to your rear switch (both up and down). If you do confirm that power is going to your rear switch, check to make sure it's actually getting there. Keep going from there. Basically start at the beginning and trace it to the end. You'll find your problem.
Old May 16, 2014 | 05:48 PM
tdappleman's Avatar
tdappleman
I had an issue with the same door. It ended up being a chafed wire inside the loom which is visible when the door is open. Mine would work 100% of the time if the door was open and about 50% of the time when the door was closed. Pull the loom back and look at the wires for any which may have the insulation worn on them.
Old May 17, 2014 | 08:13 PM
wallz's Avatar
wallz
This is going to be the way to find the problem.
Fixed mine a few years ago. Same thing was happening with mine.
quietman
Dec 12, 2018 11:53 AM
Az_Green_Machine
Apr 24, 2015 10:29 AM
MNExcursion
Dec 18, 2013 09:07 AM
jackiegibson
Jun 24, 2010 06:57 PM
vividimage
Jun 28, 2008 10:00 PM
