Torque Converter
Old May 19, 2014 | 04:53 PM
whitetmw's Avatar
whitetmw
Originally Posted by Y2KW57
I apologize in advance if this is an obvious question, but does it do the bad behavior without the chip? You said your friend had you remove the chip prior to his testing, which implies that you had kept the chip in during all of your previous testing up until that point. He said your trans is great. Have you reinstalled your chip since his tests? In between time, did you experience the behavior you are trying to address without the chip installed?
Originally I had tested it both ways. He said he would never test a unit with a chip because of too many variables that could skew the results and yes it did do it one time.
Old May 19, 2014 | 09:13 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
I totally agree with him. It sounds like your friend is very sharp. Listen to his advice!
Tom D
Jul 29, 2017 05:16 PM
Rick Stacy
Mar 11, 2017 10:17 AM
036.0stroke
May 8, 2013 08:27 AM
plourde2002
1997 - 2003 F150
Feb 9, 2004 10:37 PM
montu
All Things Towing
Mar 31, 2003 10:34 AM
