I'm running a Comp XE262H cam in my 390. I looked up the specs and Comp website recommends running the 926-16 or the 924-16 springs. Although, the machine shop sold me the 940-16 springs and I built the engine using these springs, trusting that they know what was best for my combination. I'm trying to figure out why they sold me these springs instead of the recommended springs?
Did you ask them? Only thing I can think of is they have had better luck getting the seat pressure your cam lists with the 924's w/o a lot of machine work.
I appreciate the feedback. I guess that's not terrible news. Doesn't hurt to break in the cam with weaker springs. Didn't really want to contact the machine shop. I wasn't particularly pleased with some other stuff they did. Although, they did have really good customer service. Next time I will be using a different machine shop, though. Do you think this may be causing some performance issues for the engine? The reason I'm researching these issues is because the engine just doesn't seen right. I think the performance should be much better than what I'm getting.
I would be concerned with less than 100 lbs of seat pressure. It may cause problems when you push the pedal. I agree weaker is better for break in but you need more for
hot rodding I would think.
Well, I called the machine shop to ask them about it. They sold me the different springs because of the installed height, in order to get the same pressure as the recommended springs. I'll have to do some more research and studying to fully understand it. Thanks for the feedback.
Ok...finally got around to measuring my installed height today (with the 940-16's) which is 1.94" I measured with the springs installed and the valve closed. I used a spring caliper that measured 1 30/32" (or 1.94") It's the same for both exhaust and intake valves. That's the closest I can get without removing the springs. I am able to rotate the pushrods with my fingers when the valves are closed, with no movement up/down. The lift on the XE262H cam is .513 intake and .52 exhaust, which I believe is ok for the bind height. I believe my seat pressure is too low with my installed height, hoping someone with more knowledge will give some feedback or recommendations.
Well after going through my receipts, appears I'm the one who screwed up and bought the wrong springs from Summit. Not the machine shop's fault. Would still appreciate some feedback on which springs I should be using with the Comp XE262H cam on the stock 72 truck heads. I'm looking at the Comp 926-16 or the 924-16 springs. Can't find the specs for the 924's though. Anyone else using this cam setup? What springs would work best?
Call comp and ask them. They are the ones that have done all the research on springs and cams. Did the machine shop ask for the cam spec card to know how to build the heads?
That's good advice. I'll call them this week. The machine shop sold me the cam. I bought the wrong springs and built the heads. I learned my lesson on this one.
You can run those springs for break in, and then switch them out. I'm betting they will tell you if your planning much High RPM runs to run the ones they reccomend with that cam.
Well, calling contacting Comp Cams was good advice. I e-mailed their tech support.
Here's the e-mail response I got from Comp Cams Tech Support:
"This cam should have our 926-16 for a single spring or if you are going to machine the heads for a double spring, use our 924-16. The 940-16 are too weak in pressure to be able to spin any RPM for this engine. Install height need to be around 1.800". for the single springs to work. The dual can work with a 1.900 install height. Which would you prefer?"
Since I'm running stock heads, I'll need the single springs (926-16) and shims to get my installed height correct. Thanks for the feedback everyone.
