Sponsored by: Real Truck
How to remove door panel?
Old Dec 13, 2008 | 09:59 AM
wgm114's Avatar
wgm114
I need to get at my window motor. How do I "safely and non-destructively" remove my inner door panel?
2001 F250SD Super Cab
Thanks.
Bill
Old Dec 13, 2008 | 10:46 AM
redford's Avatar
redford
FTE Leadership Emeritus
If you look in the Super Duty Tech Folder at the top of this forum
https://www.ford-trucks.com/forums/4...lder_____.html
you'll find a link to this:
Door panel removal
Old Dec 13, 2008 | 07:53 PM
ReAX's Avatar
ReAX
Pop off the window switch panel, remove 1 8mm bolt. Pop off the lens/reflector and remove 1 8mm bolt. Remove the plastic cover that hides the nuts for the mirror, the tall, black plastic piece above the door panel. Lift the door panel up, disconnect the bulb socket from the panel and set aside.
It's a simple procedure once you know to lift and not pull. I made that mistake the first time and nearly broke the lower clips.
Old Dec 16, 2008 | 03:33 PM
mattfeldt's Avatar
mattfeldt
check this out too:
Door panel removal
can't take credit for it, i found it when searching for the same this here...good luck
Old Dec 16, 2008 | 06:49 PM
SirHailstone's Avatar
SirHailstone
For the half-door is it just snapped in place?
