Interior color chips
Old May 10, 2014 | 07:48 PM
twigs's Avatar
twigs
Exclamation Interior color chips
Not sure if this has been asked in the pass. But looking for interior colors chip for my 66 F100..want to paint my steering column..I think the color is Parchment but not sure. Could not find the info on the body plate. I have a color list but not sure what the color looks like. I know the exterior is Raccoon Red.
Old May 10, 2014 | 09:16 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Could not find the info on the Warranty Plate. I have a color list but not sure what the color looks like.
COLOR code J stamped on the Warranty Plate = Rangoon Red.
AFAIK, there are no interior color chips. I have the 1966 FoMoCo Passenger Car, Truck, Bronco & Econoline exterior color chip chart.
What is the BODY code stamped on the Warranty Plate?
No truck of this vintage had a Parchment painted interior, this color was used on Mustang's.
Old May 10, 2014 | 09:27 PM
twigs's Avatar
twigs
COLOR code J on Warranty Plate = Rangoon Red.
So what color would you guess it is..I was also thinking Beige but it does not look metallic..could it be Palomino?
Should the Warranty plate tell me?
Old May 10, 2014 | 09:28 PM
NumberDummy
What is the BODY code?
Old May 10, 2014 | 09:32 PM
twigs's Avatar
twigs
Will let you know tomorrow...the truck is in the shop...
Would send you a picture of the interior..but don't know how without a URL..
Old May 11, 2014 | 01:22 PM
twigs's Avatar
twigs
Hey Bill
The Body code is 581....if you need any other info let me know.
Old May 12, 2014 | 08:54 AM
twigs's Avatar
twigs
581 is the number
Old May 13, 2014 | 07:15 PM
tripleframe's Avatar
tripleframe
581 code indicates your truck is a standard cab and originally had a red vinyl seat. Seat upholstery color and steering wheel and color were color coordinated on '66 F 100 2WD's. Therefore, your steering column and wheel should be red also. Look for signs of a repainted wheel and column. Beware, steering columns and wheels were not color matched to the exterior color!
Old May 13, 2014 | 08:00 PM
twigs's Avatar
twigs
Thanks for the info....But I know my steering wheel & Column came with the beige looking color from the Factory...It has never been replaced or painted it's beige color..Do I have one of a kind? Did they make a mistake when the truck got put together?
Old May 13, 2014 | 08:43 PM
The Masked Rider's Avatar
The Masked Rider
Do you know the history of the truck? Could it be maybe the door has been replaced at one time along with the warrantee tag? Thus making the info on the tag wrong to that truck. Also, back than, from what ND has posted in the past, you could just about order any # of things you wanted. Try that with todays vehicles.
Old May 14, 2014 | 03:56 AM
NumberDummy
Thanks for the info....But I know my steering wheel & Column came with the beige looking color from the Factory...It has never been replaced or painted its beige color.
581: 5 = Red Crush Vinyl & Red Wicker Pattern Vinyl / 81 = 81A Standard Cab.
481: 4 = Medium Beige Crush Vinyl & Medium Beige Wicker Pattern Vinyl / 81 = 81A Standard Cab.
Compare the VIN on the registration/title with the VIN on the Warranty Plate to see if they match.
People replaced damaged left doors with used doors. 99.9% of the time, they failed to install the original Warranty Plates on the replaced doors.
If the VIN's do not match, the codes on the Warranty Plate won't be correct for your truck.
Old May 14, 2014 | 11:46 AM
twigs's Avatar
twigs
Yes I know the history very well..It was my Dad's truck..
Old May 14, 2014 | 11:53 AM
twigs's Avatar
twigs
They are the same
The Vin and the Warranty number matches perfectly...
The inside of the truck is Red like you say but the steering column & wheel is like the Med Beige you stated..
Old May 14, 2014 | 05:15 PM
Conserv's Avatar
Conserv
Just trying to eliminate variables: your father bought the truck new and no one other than your father and you has owned it?
Regards,
Steve
Old May 14, 2014 | 05:47 PM
twigs's Avatar
twigs
Regards,
Steve
Yep you are right...
Elbow392
Apr 27, 2019 10:17 AM
reddogracing
Paint & Bodywork
Feb 17, 2017 09:25 PM
PNYGTA
16
Jun 6, 2014 09:13 PM
ms_michelle
16
May 1, 2010 04:26 PM
boond0cksaint
Aug 20, 2004 07:31 AM
