Bed Cap Hoist System
Old May 12, 2014 | 05:19 AM
capt caper's Avatar
capt caper
good stuff. But what did was build a rack in the yard as high as the top bed rail. I then use pvc pipe under it to roll it off and onto the rack. Then opposite to go back on. This goes fast. I have the cap that is very high in the back and it weights around 200lbs.
This is for those with out a high ceiling in there garage.
Old May 12, 2014 | 01:12 PM
porthole's Avatar
porthole
I have this winch from Northern Tool.
The mount is a piece of 23" pipe welded on each end to 2" angle, about 5' long.
Lagged to 5 rafters.
I don't use it with the current truck, but used it regularly with the last.
I made up a sling for my fiberglass tonneau cover, but for past vehicles I through bolted stainless eyebolts to use as pick points.
I also made up a spreader bar to keep from pinching the top when lifting.
The motor is attached to the pipe with "U"straps. This allows me to slide it side side for alignment purposes.
Old May 16, 2014 | 04:06 PM
Layson's Avatar
Layson
Originally Posted by garmford
When my wife and I decided to switch from a travel trailer to a fifth wheel I has to do something with my cap too. Last thing I wanted to do is lay it in the weeds somewhere behind the house. I found a person online that did some similar to what I have done. I ordered most of it from Harbor Freight but I am sure you could find most of it at a good hardware store. I think Harbor Freight is the only place to get the winch for the wall. The 2x4's are screwed into the roof trusses. I have never let it down since I raised it up five years ago. The only advice that I could give is to cut the eye bolts off that hang down past the nut under the 2x4. I didn't and it scratched the paint on my truck box but that's what I get when I rush things. I had the lumber laying around the house already and probably spent less than $100 on the rest of the hardware. Good Luck!!
Mine is just like that too. Even the same winch...LOL. One thing I did is use a drill for the handle and just spin it up or down!
Ronnie Basil Smith
Dec 5, 2020 02:32 AM
sunuvabug
General Automotive Discussion
Oct 28, 2018 06:03 PM
Dogmann
Nov 12, 2013 11:20 AM
Bowie
Sep 28, 2011 12:59 PM
E350superduty
Aftermarket Products
Nov 28, 2005 06:30 PM
