Now my 1989 E150 is needing attention
Old May 9, 2014 | 07:10 PM
VannerDude's Avatar
VannerDude
Hi Wizards! I'm back after getting my son's '90 Shorty taken care of awhile back. But now my van needs a little tweaking. It sits more than it runs but I'm going to start using it for towing my boat like I used to.
Anyway, the issue's a code 31. Am I on the right path checking out the EGR? Does it avail itself to cleaning, or do I need to replace the position sensor only? I guess I'm just getting old as I can't remember this from a few months ago.
I just spent two days reading from the last page, backwards to page 118 and saw NO code 31 info. (I was bored). Thanks VannerDude.
Old May 9, 2014 | 07:28 PM
econolinemanor's Avatar
econolinemanor
I would do both while I was in there and replace all the rubber hoses and lines I could find.......
Old May 9, 2014 | 07:39 PM
VannerDude's Avatar
VannerDude
Do both as in 'replace both', or clean EGR and replace sensor?
Thanks for the reply by the way....
Old May 9, 2014 | 07:49 PM
econolinemanor
You could clean it if it's never been done, reset the light and see what it does. If I got to craw up in there I'm doing it all....LOL
Old May 12, 2014 | 11:58 AM
VannerDude's Avatar
VannerDude
You know, for what it's worth, first I'm going to just reset the light. The reason is that when I was trying to figure out my sons' 1990 Shorty van probs, I swapped out parts from my van. (Mine had no CEL prior to that so we'll see). Makes sense to my broke ***.
UPDATE 5/12 - No go yet. Did the battery cable reset try, but as soon as I reconnected the battery and started the van, the light came right back on in a couple of seconds. Calling for parts now.
UPDATE 5/13 -Located parts but on hold. Something is leaking coolant in a constant drip on my driveway. Started pulling airbox/hoses, etc to take a look but it's already too hot outside, and I'm too old. Gonna be a hot week here near the bay.
Old May 17, 2014 | 06:29 PM
VannerDude's Avatar
VannerDude
Hope I'm not boring you guys but I'm so PRO-UPDATE that I figured I'd keep following up.
5/17 Found the lower hose bulging at the water pump connection, new hose installed. Hoping to fill with coolant and get my sensor/gauge working again.
***Installed hose, leak appears now to be water pump. Going by Napa Auto to pick up.
billingslm1
1983 - 2012 Ranger & B-Series
Feb 20, 2012 08:43 AM
rotundra
Jan 20, 2008 02:44 PM
Ajdawg
Jan 3, 2007 01:49 PM
icanfixthat
1978 - 1996 Big Bronco
20
Jan 3, 2007 08:46 AM
kevin-11
May 4, 2005 12:42 AM
