53 9 inch install. Which Shocks?
Old 05-09-2014, 06:28 PM
Giesterfarher™'s Avatar
Giesterfarher™
Giesterfarher™ is offline
Hi everyone! I'm getting close to done with the 9 inch. Just need to fab up the lower shock mounts.
Since the frame still has the original crossmember and upper shock mounts in excellent shape, I figured I'd just order a stock set of Monroe Max Air hocks, pn MA727. Yeah. Right. Nothing is ever easy.
Went to the local parts hut and told the counter guy what I wanted, and what it was for. Turns out, he owns a 54, and he said his shocks had the eyelets on both ends, like the computer and the opened box showed.
http://c.shld.net/rpx/i/s/i/spin/ima...sm=0.9,0.5,0,0
Mine, obviously not. It is designed for the straight stud on the top, and the eyelet on the bottom. What gives?
http://cdn.stylincdn.com/is/image/Au...0_1?$STT_Main$
What do you guys have on yours? I really don't want to hack a perfectly good, unrusted or bent crossmember when I don't have to. I can make any lower mount I need. I just need to have a starting point, like a part number. I'm kinda set on air shocks. Love em. Can't not install them on everything. But a pn for a stocker, or a different application you used will do for a starting point that I can use to cross reference. And Pics please if you have them. Thanks!
Old 05-09-2014, 06:44 PM
vintage tin's Avatar
vintage tin
vintage tin is offline
i put a set of air shocks on my 85 bronco 2,it had the stud on top like you have.may just work for you.
Old 05-09-2014, 06:49 PM
49willard's Avatar
49willard
49willard is offline
I can't help you for a F100. The air shock in the picture looks like what I used on my F-1 with a 9 inch rear however the upper mount in the F-1 is a stud. The location of the factory stud did not work well with the 9" rear so I welded on a new stud. I painted the white shocks (as purchased) red.
Old 05-09-2014, 07:50 PM
Giesterfarher™
Thanks Guys. The 85 Bronco II is a good option, I think. The vehicle weights are similar.
Old 05-09-2014, 08:02 PM
Giesterfarher™
Hmm. I just found this site, and I learned something interesting.
My frame isn't what I thought it was. It's a 56 frame at the earliest. And apparently up to a 1960. No biggie. It'll still work.
KYB, Monroe, Rancho, Unity | SHOCKS.COM
Old 05-10-2014, 07:37 PM
bjmayberry2's Avatar
bjmayberry2
bjmayberry2 is offline
Great site, and prices!!! Thanks for posting.
Old 05-10-2014, 07:53 PM
AXracer's Avatar
AXracer
AXracer is offline
If you are going with Monros, it doesn't matter what the weight is, they all have the same internals.
Old 05-12-2014, 11:36 PM
1oldtimer's Avatar
1oldtimer
1oldtimer is offline
Go online to monroe on find their specs, choose the ends you need and get the extended/collapsed info. I used Monroes on my '47 car because they were softer and KYB Gas A Just on my '54 panel because they're stiff.
Old 05-13-2014, 07:19 AM
Giesterfarher™
I ended up with a set of Monroe MA805's. They fit perfectly.
Old 05-14-2014, 12:34 AM
das54's Avatar
das54
das54 is offline
thanks for that link. They have very good prices.
They list MA727 for the 55 F100 but my truck rides a lot lower than stock so I'm going to try the MA803 because it has a compressed length that is 2 inches shorter
Old 05-14-2014, 01:40 PM
Hell_Fish's Avatar
Hell_Fish
Hell_Fish is offline
I used shocks for a 65 F series truck, but my 56 is a little different than yours. The upper mounts are facing the rear of the truck on mine.
Old 05-14-2014, 04:31 PM
Giesterfarher™
I guess that makes my frame newer than 56 as well. I'm beginning to wonder just how consistent Ford made these trucks.
I guess I need to go out and actually get the frame number and run it.
Old 05-15-2014, 11:33 AM
Hell_Fish's Avatar
Hell_Fish
Or not. My 56 was heavily modified. Talked with my uncle this morning, my 56 has a later frame with a deeper kick up, used to create proper ride height after adding in the lowered GM from clip.
Tushy
08-24-2014 11:58 AM
OregonJen
1947 and Older Ford Trucks
02-11-2012 12:19 PM
Showpanther
01-21-2011 07:17 PM
fatfenders
23
02-01-2005 07:00 AM
fatfenders
08-13-2002 12:14 PM
Quick Reply: 53 9 inch install. Which Shocks?
