Got a maybe issue???
Did you touch the stock waste gate when you rebuilt the turbo? If not your stock wg spring could be weak/ faulty. How does the truck drive in the other performance settings?
Also, is it all the time or intermittent? Are you sure it's not just your engine fan engaging?
(I really don't know ****, but I have a lot more knowledge than cash)
Denny
Start at the top and go to the bottom misting it with simple green strait.
Ignore the look, just keep it moist.
When your done with the top, hose it off (no pressure wash, some will say different) Touch up what you see you missed.
After your done spray it down again from the top, Simple green, and then go after the underside, Don't let the top dry. Go to town again on the bottom and don't ignore the hard to reach spots because those are the spots you'll be looking at in the future to do repairs.
When your done, hose!!!!! it off and check your work. Apply as needed.
The only thing I cover and protect is the power steering cap. Waste a rubber, works great.
Guys that P wash they're rigs in my circle have a lot of problems in retrospect and can't pin point them because they force moisture into too many places at once. Thus multiple problems to solve.
Drivers side valve cover has a loom that should be highly thought of while doing this. It controls generally everything that will make it run poorly/start hard if compromised.
Do it on a gravel drive if possible without a tree hugger as a neighbor.
You'll really appreciate the amount of effort you put forth when you are trying to do regular and troubleshooting maintenance.
(Side note) Michigan here, too cold to do a GPR change-out on a flash, so I wheeled into my trusty shop and popped the hood. Mine is a E 99 F250, the shop stopped dead and everyone that spins a wrench was in awe over how clean the E bay was. I even got charged less. My truck is a plow/work/tow/drinking on trails workhorse on the outside. Cleaner than my Grammys stove on the in. Just sayin'.
Others will chime in. 250,000 miles of practice. No electrical problems.
