Coolant Filter?
Old Feb 28, 2017 | 07:48 PM
Flaman's Avatar
Flaman
Question Coolant Filter?
So, which coolant filter is everyone running?
Thanks,
Rick L.
Old Feb 28, 2017 | 07:58 PM
Bumblebee04's Avatar
Bumblebee04
Wix 24070
About $8 each on rockauto
Old Feb 28, 2017 | 08:23 PM
Yama4fitty's Avatar
Yama4fitty
I just purchased an XDP setup and it should be here tomorrow
Old Mar 1, 2017 | 06:12 AM
pass1over's Avatar
pass1over
IPR's setup. Full flow, never buy another filter. Best option for a coolant filter IMO
Old Mar 1, 2017 | 06:21 AM
FordBlueHeart's Avatar
FordBlueHeart
I realize lots and lots of people swear by this setup, but hasn't there been issues with hoses and clamp quality? Not everyone has experienced the problems (or they don't know it). Or was it the intake manifold? Hmmmm, I'll see if I can find the thread.
EDIT: Here's what I was thinking of. https://www.ford-trucks.com/forums/1...-feedback.html
Old Mar 1, 2017 | 06:29 AM
Flaman's Avatar
Flaman
Never mind, just saw the install diagram.
Thanks,
Rick L.
Last edited by Flaman; Mar 1, 2017 at 06:40 AM. Reason: Didn't do all my research.
Old Mar 1, 2017 | 07:33 AM
pass1over's Avatar
pass1over
first i've heard of those issues. I've had mine in for about 13k miles now and no leaks. It's pulled some crap out of my cooling system for sure, just rinse it out and replace.
Old Mar 1, 2017 | 07:48 AM
TxMav's Avatar
TxMav
I use the NAPA 4069 on my XDP setup. About $14.
NAPA 4070 works too but it is longer and harder to remove.
NAPA 4069 (one inch shorter).
Old Mar 1, 2017 | 07:50 AM
TxMav's Avatar
TxMav
A while back, someone was good enough to post this list. I saved it off.
This is a list of part numbers for the spin on filter used by most (pretty much all) of the aftermarket coolant filter systems and none of these contain a SCA.
Fleetguard WF-2077
Baldwin B5134
Baldwin B5089 (shorter)
John Deere RE11992
Caterpillar 9Y4528
Cummins 3300721
Wix 24070
NAPA 4070
AC-Delco WF-108
Fram PR3383
Donaldson P554685
Alliance (Freightliner) WF2077
CarQuest 89070
Hasting WC8
Purolator W54451
Old Mar 1, 2017 | 08:06 AM
Flaman's Avatar
Flaman
Please let me know what you think of this setup when you receive it. Wish it had black hoses so it would look more like stock.
Thanks,
Rick L.
Old Mar 1, 2017 | 09:50 AM
Justus6.0L's Avatar
Justus6.0L
I use Wix filters. If you are going to get a coolant filtration system, make sure you get one with dual isolation valves so you don't leak coolant all over the place when you change filters.
Old Mar 1, 2017 | 12:24 PM
diesel_dan's Avatar
diesel_dan
Thanks,
Rick L.
I'm a fan of XDP in general and their coolant filter specifically, which was one of the best deals going for quite a while (remember to use discount code DIESEL10 at checkout for 10% FTE discount). However there are now a lot of knock-offs out on eBay...
Then there's the all-silicone Mishimoto unit, which I do believe you can get in colors (like black). Look around, just make sure you get one with those ball valves on the in/out of the base and that it comes with a good mount that fits our 6.0s...
Old Mar 1, 2017 | 12:55 PM
Bumblebee04
If you like black hoses, electrical tape is cheap! Added layer of protection too LoL
Old Mar 1, 2017 | 01:15 PM
Justus6.0L's Avatar
Justus6.0L
Or you could use that hose/pipe cover stuff that is corrugated plastic.
Old Mar 1, 2017 | 01:31 PM
Bumblebee04
Even better protection! Great idea!
