Looking for timing marks
Old Jun 25, 2004 | 10:27 AM
65vamonster's Avatar
65vamonster
I have a 65 F250 and it is my first vehicle where the timing is not set by a computer. I am trying to check it because the truck sounds like it starts hard. Someone told me this could be from too much timing advance. I went to check the timing but I think the tab with the marks on it is not there. Is there any way to get around this or find one.
Old Jun 25, 2004 | 10:51 AM
Randyb12's Avatar
Randyb12
Are you looking from the passanger side down at the top pass side of the balancer?
If so go to a junkyard and find one off a FE.
Old Jun 25, 2004 | 02:16 PM
Mike G's Avatar
Mike G
The tab mounted to the timing cover will not have the marks on it, that is strictly the pointer. the timing marks are located on the harmonic balancer. Since you have not done this before, I would take the time to clean off the balancer and locate your morks before jumping into the setting of the timing.
Oh yea, welcome aboard!
--Mike
Old Jun 25, 2004 | 02:31 PM
87 XLT's Avatar
87 XLT
If this was mine, i'd just set it by ear. Advance it til it pings when you stomp on it, then back it off a few degrees.
Old Jun 25, 2004 | 05:15 PM
gtex's Avatar
gtex
in the second picture down, you can see the balancer and the tab. your balance won't look quite like this but it should help you find it.
http://www.thedreyerfamily.com/69f25...valmay2004.htm
olderford76
New Member Introductions
Sep 14, 2015 11:21 AM
2zwudz
Nov 8, 2013 12:26 PM
madmader
1978 - 1996 Big Bronco
Aug 29, 2005 06:13 PM
Studenut65
Modular V10 (6.8l)
16
Sep 22, 2004 08:31 PM
66fdtrucknut
Apr 20, 2004 10:07 PM
