Replace vehicle speed sensor?
Old May 8, 2014 | 06:59 AM
subford's Avatar
subford
Originally Posted by bebyb
Wow, kinda makes ya nervous about owning that thing lol.
You do not have a pressure switch on the MC in your setup as talked about in the trucks burning up above.
Old May 8, 2014 | 07:15 AM
subford's Avatar
subford
It does not look like the speed sensor can cause your problem.
Here is your tests:
Old May 8, 2014 | 09:37 AM
bebyb's Avatar
bebyb
Here is your tests:
Thank you!
Old May 8, 2014 | 10:21 AM
andym's Avatar
andym
Originally Posted by mdh1701
Um, my 94's speed sensor is in the rear end, there is no speed sensor in my tranny at all. Unless I am missing something...
Ford moved the speed sensor to the rear end in 1992. Prior to that the sensor was still there but it's only used for the RABS. The speed sensor is in the transmission or transfer case tail housing in 1991 and earlier trucks.
As for the OP... the connector (sensor?) on the front of the brake master cylinder could be bad, or like previously mentioned float could be stuck. There is also a non-replaceable fuse(fusible link?) in the wiring harness going to that connector on the BMC, at least that's what it says on my 94, if bad it says to replace the whole wiring/plug/fuse assembly. Check that out too. Just throwing ideas out there. Hope I was helpful!
Like Bill said... none of this applies to a 1989 truck except the stuck float.
jcjk420
Aug 19, 2007 07:50 AM
Schmidty3vb
1997 - 2003 F150
May 9, 2007 12:02 AM
3-RANGERS
1997 - 2003 F150
Feb 1, 2007 07:51 AM
Lushman
Mar 6, 2006 02:32 AM
GammaDriver
1997 - 2003 F150
Jun 30, 2005 08:34 PM
