Sponsored by: Real Truck
Speed Sensor location?
Old Mar 5, 2006 | 10:46 AM
Lushman's Avatar
Lushman
Maybe a stupid question, but my ABS light has been on since I purchased my truck a couple weeks ago and I checked my brake fluid level and it is fine. Most of the info I have from FTE seems to say replacing the speed sensor will probably fix this. I purchased one Friday and am hoping to put it in later today, but where is it? (I don't have a shop manual yet, in another thread)
Old Mar 5, 2006 | 10:49 AM
CAT_man_963's Avatar
CAT_man_963
I think it should be on top of the rear axle - right on the differential. Should be the only sensor in that area.
Old Mar 5, 2006 | 10:56 AM
Lushman's Avatar
Lushman
Thanks, I should be able to find it from there!
Old Mar 5, 2006 | 11:08 AM
superpony18's Avatar
superpony18
There is also speed sensors in the front nuckles. That is were mine was bad. you have to remove the brake discs to pull them out and check them visually. There is a way to check them without removing anything but I don't remember.
Old Mar 5, 2006 | 08:48 PM
wildride454ss's Avatar
wildride454ss
ya check abs code with a scan tool.
Old Mar 5, 2006 | 09:05 PM
Lushman's Avatar
Lushman
I didn't have a scan tool I have FTE which is just as good! I read about this problem in several other threads and for the $22 sensor was willing to try it and it worked!!!!!!!!! No more ABS light and I didn't need to go to a dealer!
Old Mar 6, 2006 | 02:32 AM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
Thread moved to the Super Duty Forum
