Sponsored by: Auxito
Brake Speed Sensor Installation
Old May 8, 2007 | 11:03 PM
Schmidty3vb's Avatar
Schmidty3vb
How difficult is it to replace the brake speed sensor in a '99 F150? Do I need special tools? Also, how do you bleed the clutch fluid from a manual transmission in the same truck? One more question, does anyone know a rough cost of replacing the alternator? Is that easy to replace? I appreciate your time and energy to these questions!
Old May 9, 2007 | 12:02 AM
wgotthardt's Avatar
wgotthardt
The rear abs sensor (on top front of differential), is about a 5 minute job..
unplug old, wipe off surrounding grease/dirt, remove single bolt (pretty sure it's 10mm) and remove...install new sensor, tighten bolt, plug back in.
