'66 Two Tone Tailgate Masking?
Old May 7, 2014 | 02:17 PM
theastronaut's Avatar
theastronaut
We're ready to spray the paint on the bed of the '66 we're restoring but can't find detailed pictures of at two tone tailgate to see where the colors splits. Can someone post pictures of the mask line on a tailgate?
I have this picture but I can't really tell where the mask is at on the stamped ridge.
Old May 7, 2014 | 02:33 PM
TA455HO's Avatar
TA455HO
Lead Gopher
My two tone truck tailgate has not been repainted. I'll get some pics of it later tonight if someone else doesn't post some first.
Old May 7, 2014 | 05:05 PM
jowilker's Avatar
jowilker
As long as it splits under the side molding, I don't know that it has to be exact. Use the image as a guideline.
John
Old May 7, 2014 | 09:07 PM
F&M's Avatar
F&M
I'd mask it with the gate on...then remove to paint or the lines may not match.
Old May 8, 2014 | 07:22 AM
theastronaut
We need to know where the color splits inside the tailgate too.
Old May 8, 2014 | 10:21 AM
TA455HO's Avatar
TA455HO
Lead Gopher
See if these help at all. The area where it transitions from front to back is a bit vague on both sides. I don't think they spent a lot of time masking that area.
Old May 8, 2014 | 11:07 AM
theastronaut
That helps a ton, thanks!!
Old May 8, 2014 | 11:53 PM
tbm3fan's Avatar
tbm3fan
It was suggested that you lay the tape first and then remove the tailgate for painting. I highly, highly recommend that as I just went down this road. The actual line will be located somewhat below the accent line on the top but is more determined where the line is down the side of the bed. My line on the bed went originally right through the middle of the trim holes. You then have to make the turn around the end cap which is delicate and this was with 1/4" fine line tape
Old May 9, 2014 | 12:02 AM
tbm3fan's Avatar
tbm3fan
This transition area has more white paint that mine does. Mine has almost all green in the area with just the inside of the lips curving around having white. So that is the way I did mine.
Old May 9, 2014 | 08:10 AM
theastronaut
That's what we did- tailgate first and mounted it to match the lines on the bedsides. The holes down the driver side are off from the factory, so we had to work around that. Its off so far that we'll have to use 3M double sided tape to attach the trim or else it'll be crooked.
Matt Pegan
Dec 7, 2016 04:44 AM
finchturf
Sep 24, 2016 09:48 AM
rgs4x
Ford Truck Parts for Sale
Feb 2, 2015 03:31 PM
mudder460
Paint & Bodywork
16
May 17, 2011 02:07 AM
tlb
25
Jul 22, 2009 10:42 PM
