Backfiring through carb
Old Jul 6, 2003 | 10:10 AM
Chuck Batt's Avatar
Chuck Batt
77 Ford van 351W
Starts fine, idles fine, drives fine for 30 to 45 minutes. Then, when stopped, begins to idle rough. Taking off produces popping through the carb. Then as car is driven popping continues intermittently.
Have replaced plugs, ditributer and rotor, fule filter, PCV valve, fuel pump. Car passed emmission test when taken in before the 30 to 45 minutes went by.
Old Jul 6, 2003 | 12:13 PM
Colossus's Avatar
Colossus
My truck does this every now and then, used to do it all the time.
Check timing and the choke. That's all I can think of at the moment.
Old Jul 6, 2003 | 01:16 PM
Chuck Batt's Avatar
Chuck Batt
Thanks. We'll give it a try. If anyone else has any ideas, please let me know.
Old Jul 6, 2003 | 01:21 PM
Ds7776's Avatar
Ds7776
When my F100 did this it did it more than your van does, what I did was replace the power valve on the bottom side of the carb and it fixed that.
Old Jul 6, 2003 | 05:02 PM
Torque1st's Avatar
Torque1st
Posting Legend
Check your ignition module, heat can make them intermittent. Parts stores will test them for free. If in doubt replace it with a Motorcraft module only. Mount it with 1/4" spacers so that air will circulate under it.
Also check your engine with a vacuum gage to see if you have a leaking valve.
Old Jul 6, 2003 | 08:49 PM
jar06896's Avatar
jar06896
I'm curious. I just changed out a leaky intake/valley pan gasket, and I kave a similar problem. Truck runs great at idle, but at about 2200-3000 rpm, it gets rough, and lacks power. I changed the fuel filter, checked the plugs, checked all the gaskets and played with the timing. popping through the carb...timing too advanced? Advice?
78 F250 351M 4spd,np205.
Old Jul 6, 2003 | 08:56 PM
Colossus's Avatar
Colossus
Was the gasket properly installed? I did read that air leaks in any of the engine or carb gaskets can cause problems.
Old Jul 6, 2003 | 09:25 PM
jar06896's Avatar
jar06896
As far as I know I installed the gasket properly. I haven't yet tried carb cleaner around it, but that will be next.
Old Jul 6, 2003 | 09:56 PM
Colossus's Avatar
Colossus
Cleaning the carb can help, you might want to check if your carb is calibrated properly, and make sure the choke is working - that's what was wrong with mine.
Old Jul 6, 2003 | 10:38 PM
1975 f150 360's Avatar
1975 f150 360
my 1975 f150 360 backfired through the carb and i found out the timing was off i had to set the points right
1975 f150 360
Old Jul 7, 2003 | 06:02 PM
okiebronco's Avatar
okiebronco
ive also had them pop through the carb due to a clogged fuel filter....
Mdc9966
15
Nov 12, 2015 11:51 AM
GRNMSTR
Escape & Escape Hybrid
Oct 9, 2014 08:55 AM
kj2wilson
Mar 9, 2014 01:12 PM
jbancroft
Jan 20, 2014 09:13 AM
