I know there are kits out there for the 2005 Super Duty Grille to be made to work on the 2000 Excursions....but would a grille from a 2000 F250 fit a 2000 Ford Excursion? My mind says yes - but everything points to no, no site says it would fit.
Found the grille I am looking for, but only lists for the f250, f350, f450.
I have Plastidipped my stock grille, but that crap chips so easy lol At least it was cheap
Some forums I am on, people get grilled for questions like this lol So I was expecting a different result lol
This should do it for cosmetic mods (minus a paint job or another wrap...truck was wrapped and still working on getting it all off).
Next up is a 4 inch lift and 35s...suspension has 133,000 miles on it, the motor and tranny have 70k...so suspension work is needed, might as well lift it
The headlights for the newer Xs will not fit ours without cutting the support. Mine are like the '03. Clear top and bottom, but I do like the ones you show!
My 2003 OEM headlights don't look too bad, but the blacked out ones you posted look sweet.
I stuck on some LED DRL's just above my fog lamps,
however those LED's integrated into the aftermarket housings would blend much nicer. I was thinking of keeping the stock chrome grill surround but Plasti dipping the grill itself in black like yours. You said it doesn't hold up well?
I might not have done enough coats, this was two coats and its been on for about 3 months. I don't do a lot of driving (my round trip to work is 6 miles) and there are already three spots I can see the chrome lol
Great close-ups of your grill. I think I'll do mine the same way. Maybe 2-3 coats will hold up. I like the semi-gloss look and the rubberized finish might let those damn bugs bounce off
