Sponsored by: Real Truck
Bad ground? Dead switch? Help!
Old May 5, 2014 | 07:45 PM
Dead Truck's Avatar
Dead Truck
Sunday when leaving the drag strip, (I'm the announcer at the new Fontana, Auto Club Dragway,) my 1988 F350 went "click!" A pal jumped me with his diesel, nothing, another guy hooked up his mobile jumper and along with the diesel my engine turned over super slow. Finally a few guys came over and pushed me across the parking lot and I dumped the clutch, drove home.
My truck eats starters every two years like clockwork, but this high dollar starter was only a year old. When I got home I hoped it had charged enough, if that was the problem, but it wasn't turned it off, and it was dead dead.
Long story short-er...New starter, perfect big battery, new solenoid, no change. Nothing. No clicks even. My battery ground wire connection looks crappy, so I ran a jumper cable to the starter housing, one click, then nothing.
Ran the jumper to the plus pole on the starter, spins over but won't start even with the key in the on position and the clutch pedal depressed while the cable was connected.
So to recap - I have a new tested starter, new solenoid that clicks when jumped across, battery at 13.8 volts.
Also noticed ~ wipers don't work ~ head lights don't work.
Seems like a ground problem but I'm grasping at straws now. It's my daily driver and I need to get 'er going.
Anyone ever have this problem?
Thanks
Old May 6, 2014 | 12:24 AM
Dead Truck's Avatar
Dead Truck
[QUOTE=Dead Truck;14321610]Sunday when leaving the drag strip, (I'm the announcer at the new Fontana, Auto Club Dragway,) my 1988 F350 went "click!" A pal jumped me with his diesel, nothing, another guy hooked up his mobile jumper and along with the diesel my engine turned over super slow. Finally a few guys came over and pushed me across the parking lot and I dumped the clutch, drove home.
Thanks
(WTF is with the ads??)
Old May 6, 2014 | 07:58 AM
DavidB's Avatar
DavidB
See the video at the end of this thread:
https://www.ford-trucks.com/forums/1...turn-over.html
Old May 6, 2014 | 08:45 PM
Dead Truck's Avatar
Dead Truck
I will do this test.
thanks
Bruce
Old May 8, 2014 | 12:39 AM
Dead Truck's Avatar
Dead Truck
Update. The cable from the battery to the solenoid was corroded internally. Couldn't see it, looked ok on the outside, but it was dead.
Old May 8, 2014 | 08:05 AM
DavidB's Avatar
DavidB
Good Job! Thanks for posting what you found.
kaotikedge_111100
21
Sep 29, 2008 07:34 PM
itcosthowmuch!!??
1978 - 1996 Big Bronco
Jul 15, 2006 06:50 PM
degdawgs
Mar 6, 2006 08:24 PM
Mike Roma
May 8, 2005 11:34 AM
jln_Wasabi
Electrical Systems/Wiring
Mar 3, 2004 10:36 PM
