Old Jul 5, 2003 | 10:25 PM
fordbeast_80's Avatar
fordbeast_80
352
I have a 352 from a 1965 ford galaxy 500 XL, came with a 4bbl,dual exhuast does anyone know what kind of power these put out? and how much would an aftermarket aluminum intake,headers and a cam add to an FE? the motor has really low miles. oh yeah I think it is an X motor if that helps.
Old Jul 6, 2003 | 08:16 AM
baddad457's Avatar
baddad457
352
If it's got a 4 bbl, then it's not a 352. All FE blocks have a "352" cast into the left front of the block. What you have is either a 390 or a 427 ( most likely a 390 though, 427's are rare)
Old Jul 6, 2003 | 01:03 PM
BB's Avatar
BB
352
Well, from '64-'66 there was a X code 4V 352, 250 brake horsepower @ 4400 rpm, 352 gross torque @ 2800 rpm, 9.3:1 comp.
Old Jul 6, 2003 | 01:53 PM
dinosaurfan's Avatar
dinosaurfan
352
fb_80, you might very well have a 352. Some of them were in mid 60s cars witha 4 barrel carb. As for ALL FEs having a 352 cast in the block, where did that come from ? While it is true that lots of FEs do, some have a mirror '105' in the front, some have 427, some don't have anything cast in front. Are you going to put this engine into a truck ? The cast iron intake you have is very heavy (75lbs) and not the best breather. The iron exhaust probably sucks too. And the grandma cam isn't helping either. Adding 150 hp or more to this engine is really no problem, but the pieces you choose will be dictated by the usage the car will get. How much power do you want ? How much $$$ can you spend ? But before you consider any new goodies, you might want to think about getting hardened seats installed under your exhaust valves, so the engine will happily burn unleaded fuel. 'cause thats all we can get today. DF
Old Jul 6, 2003 | 02:50 PM
fordman102's Avatar
fordman102
352
I also have a 352 with the 4 bbl. It is sitting is a 67 Custom. I havn't measured the stroke but I'm sure it is a 352. The car and the air cleaner both have the 352 emblem. I plan on putting the engine in my 51 F1 next year after rebuild and the upgrades mentioned earlier (alum. intake, cam, etc)
Old Jul 6, 2003 | 03:21 PM
fordbeast_80
352
Thanks for the info guys, I'm pretty sure it's a 352 not sure if I'm keeping it in the car or putin it in a truck.
so any one got any ideas on a streetable cam,header recomendations, intakes, carb? don't have a lot of money every thing would take some time, what kind of power should I expect with these mods.
Old Jul 6, 2003 | 09:47 PM
redneck hillbilly's Avatar
redneck hillbilly
Ford Performance by Pat Ganahl lists the 65 4v at 250hp/4400rpm, 352ft-lbs/2800.
OliverFrance
May 31, 2016 02:28 PM
hillmstr1
Mar 12, 2016 11:29 AM
bphirt1
Oct 4, 2015 10:02 AM
nerksa
Mar 10, 2015 08:28 PM
taylorjgreen
18
May 8, 2008 06:57 PM
