52 running engine
Old May 17, 2014 | 12:20 PM
  #31
Jolly Roger Joe's Avatar
Jolly Roger Joe
Originally Posted by tractormanbill
Best as I can tell it was last running in 1962 or 22 years ago.
TractormanBill
Good luck. And that would be 52 years ago. Just off by 30 years.
Old May 17, 2014 | 02:50 PM
  #32
arctic y block's Avatar
arctic y block
Acetone and ATF mixed 50/50 makes a great penetrating oil.
Old May 17, 2014 | 04:42 PM
  #33
tractormanbill's Avatar
tractormanbill
tractorman
Jolly Roger Joe,
Think it last was running in 1992 which would probably be 22 years ago.
Just got it running, seems to be hitting on all 8 OK but the right manifold is cracked which makes it a little noisey.
I have it running on a 12 volt coil & battery with the power to the 6 volt electrical system un-hooked to save it.
Have video & sound that I will try to post.
TractormanBill
Old May 17, 2014 | 07:35 PM
  #34
Jolly Roger Joe
Jolly Roger Joe,
TractormanBill
Oh, OK. I misread your comment about 1962 OR 22 years ago. I took it to mean 1962, which was 22 years ago.
Glad you got it running! Love to see the video!
Old May 17, 2014 | 07:45 PM
  #35
arctic y block
IT'S ALIVE. Way cool bud. Run the tires off, Then buy some more. Enjoy.
Old May 17, 2014 | 11:58 PM
  #36
tractormanbill
tractorman
Hope I have uploaded this file correctly as it is a movie & sound of the 52 F-6 running.
Didn't seem to work.
Can anyone help with what I should to to list the file? I think it is a MOV file.
TractormanBill
Old May 18, 2014 | 10:22 AM
  #37
Jolly Roger Joe
TractormanBill
I've had trouble with videos for over a year now.
Try uploading it to Photobucket and just copy the link into your post. That's what I've had to do.
Old May 21, 2014 | 03:36 PM
  #38
tractormanbill
tractorman
Let see if this works?
http://billstractor.com/52fsound.MOV
http://billstractor.com/52fsound2.MOV
TractormanBill
Old May 21, 2014 | 03:43 PM
  #39
tractormanbill
tractorman
Got the 52 F-6 running this last weekend.
Now brakes and see if it drives.
Looks like the links worked.
TractormanBill
Old May 21, 2014 | 03:48 PM
  #40
arctic y block
Way cool Bill. I love it.
Old May 21, 2014 | 03:54 PM
  #41
tractormanbill
tractorman
52 F-6 running
Sounds like it has a cam in it with that exhaust leak but I haven't adjusted the timing, carb. or anything just let her rip after new plugs and points were installed that were in the glove box. Still have 2 or 3 old plugs in it that are stuck that I will work on.
TractormanBill
Old May 21, 2014 | 04:50 PM
  #42
ALBUQ F-1's Avatar
ALBUQ F-1
Did you change the oil? It sounds promising!
Old May 21, 2014 | 10:52 PM
  #43
tractormanbill
tractorman
Not yet on the oil or the filter as it was black and full enough.
All the plugs that came out looked great with no oil build-up.
It may sit a while while I get back on my F-1 rebuilding.
TractormanBill
Rimrock F1
Mar 18, 2014 04:23 PM
RedZombie
May 15, 2009 12:37 AM
Ford51
Flathead V8 & Flathead 6
Feb 20, 2006 10:37 PM
CaliFordDood
Jan 27, 2006 05:05 PM
Gear Up
Apr 15, 2004 02:12 PM
