door jamb sticker
Old May 2, 2014 | 07:38 PM
chrisb_93's Avatar
chrisb_93
door jamb sticker
I have a 1989 f 150 I need help decoding the sticker inside the driver side door
Old May 2, 2014 | 07:48 PM
bruno2's Avatar
bruno2
OK, post up the info.
Old May 2, 2014 | 08:04 PM
chrisb_93's Avatar
chrisb_93
How do I post a picture I feel like it'd be easier
Old May 2, 2014 | 08:16 PM
chrisb_93's Avatar
chrisb_93
Old May 2, 2014 | 10:24 PM
ctubutis's Avatar
ctubutis
It's a 1980, not 89.
I really wish people would post their pictures right-side up, I don't understand how people expect us to to continuously turn our head sideways or sumthin' to try and read the dang thing. Lookin' this **** up is enough of a pain in the *** as it is, twisting the picture and making it harder on those of us who do this for people ain't real cool IMHO.
Old May 2, 2014 | 10:42 PM
chrisb_93's Avatar
chrisb_93
I know its an 80 I did it off my phone and its messed up it'll say one thing and as soon as I hit post it changes it
Old May 3, 2014 | 06:57 AM
bruno2's Avatar
bruno2
Looks like you have a 9" rear end 2.75:1 gear ratio and it's open not the limited slip carrier.
Transmission could be :1978/83: RUG SR-OD Single Rail 4 Speed O/D
Chris will tell you he thinks it is a Clark 4 speed overdrive
I also saw a reference that it might be a 3 spd standard transmission.
Old May 3, 2014 | 07:10 AM
Franklin2's Avatar
Franklin2
F15= f150 2wd
E= 6 cylinder engine
P=Twin Cities MN assembly plant.
Not sure about the "J" and the "D".
Old May 3, 2014 | 07:13 AM
AZ 4x4's Avatar
AZ 4x4
Here's the full scoop
VIN – F15 (F150 2WD regular cab), E (300 CID, 6 cylinder), P (Twin Cities assembly plant), JD4848 (sequential production number)
Along the bottom of the certification label…
1G – Silver Metallic
3D - Dark Blue Metallic
DSO – 53 – Kansas City district
F151 (2wd F150 reg cab truck)
DB4
D – Knit Vinyl bench seat
B – Blue
4 – Styleside pickup box
Transmission B – Clark Manual 4 speed overdrive
Axle 13 – 2.75 ratio Ford
I believe the F0111 and T0641 were original order references for the truck, someone else can probably confirm (or correct) this
Old May 3, 2014 | 11:30 AM
chrisb_93's Avatar
chrisb_93
Thank you all for the help
Old May 3, 2014 | 03:37 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1980 has an 11 digit VIN, 1981 thru today has a 17 digit VIN
Production date 5/80 / VIN: F15EPJD4848 / WB: 133 / TYPE-GVW: F151 / BODY: DB4 / TRANS: B / AXLE: 13 / EXTERIOR PAINT COLORS: 1G 3D / DSO: 53
5/80 = Assembled May 1980.
F15 = F150 2WD Regular Cab Pickup.
E = 4.9L (300) 1V I-6.
P = Twin Cities MN Assembly Plant.
JD4848 = 1980 Numerical Sequence of Assembly, the trucks specific serial number.
133" Wheelbase.
F151 = F150 2WD Regular Cab Pickup, 5,450 lbs. Gross Vehicle Weight Rating.
DB4: DB = Blue all Vinyl - Full Width Seat / 4 = Regular Cab Styleside Pickup.
B = Ford (Clark) RUG SR-OD Single Rail 4 Speed Overdrive Manual Transmission.
13 = Ford 9" Rear Axle / 2.75-1 / No Limited Slip / 3,750 lbs. Rear Axle Capacity.
1G = Silver Metallic / 3D = Dark Blue Metallic.
53 = Kansas City MO Ford District Sales Office, where the original selling dealer ordered the truck from.
Rather surprising that the truck was assembled in MN, since there's a Kansas City MO Assembly Plant.
F0111 & T0641 cannot be decoded.
Old Mar 9, 2015 | 10:01 AM
LARIAT 85's Avatar
LARIAT 85
My truck is getting re-painted soon and the door jamb sticker is in bad shape.
Where can you get these reproduced?
Old Mar 9, 2015 | 12:06 PM
ctubutis's Avatar
ctubutis
Try:
Kevin Marti Phone (623) 935-2558 Marti Auto Works - Concourse Quality, Hobbyist Price
ECS Automotive Concepts, LLC Phone: 1-855-5-ECS-VIN ECS Automotive Concepts - Late Model Replacement VIN Door Decals
Old Mar 10, 2015 | 09:01 AM
LARIAT 85's Avatar
LARIAT 85
Thanks, Chief!
SynDave
Sep 6, 2018 08:17 AM
adams1492
2004 - 2008 F150
20
Oct 21, 2014 04:57 PM
shooer
Apr 10, 2008 06:17 PM
MichaelMuck
Apr 21, 2004 06:20 PM
