HELP, 6.0L died without warning
Old May 11, 2014 | 12:04 PM
  #31
BLADE35's Avatar
BLADE35
your right
I was just kinda generaly speaking about the Dplug and standpipes
all have the problematic HPOP until 05
BUT I hear they have been updated several times Thuru FORD so they probably LOTS better if you have a Recent HPOP that is OEM
Im sure Aftermarket HPOP is SLOWER to get the Updates in there rebuilds if at all
then theres always the Dieselsite HPOP that's "supposed" to be Improved IIC they said it had around 10 changes but Did not List them so who knows
All I can see with Dieselsite hpop is the BB has been eleminated
Old May 11, 2014 | 12:09 PM
  #32
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Originally Posted by BLADE35
your right
All OEM HPOPs are remans... point being, not sure how many "changes" or "improvements" are truly made.
Being in fabrication I hear claims all the time of "new" and "improved" and compared to the previous model the only change was a cotter pin.
Josh
Old May 11, 2014 | 12:16 PM
  #33
Bullitt390's Avatar
Bullitt390
I posted this on Anthony's thread regarding updates etc.
Update; Ford 6.0 hpop fix (continued)
Unless the remans are pinning the insert, every reman will likely fail. As we have seen over and over and over and over...
The early 6.0 HPOP, although can create good pressure, is a poor design, better served for lower pressure and run-time.
Josh
Old May 11, 2014 | 12:17 PM
  #34
BLADE35's Avatar
BLADE35
sure I know they all remans
And I am just going off what Anthony said when the blue diamond rep came out to his shop on the 9 or 10th revision who knows all whats been done sounds like more then a Cotter pin though
Old May 11, 2014 | 12:19 PM
  #35
BLADE35's Avatar
BLADE35
and you posted that when I did mine at x-mas
Old May 11, 2014 | 12:45 PM
  #36
Bullitt390's Avatar
Bullitt390
Sales Reps are paid to blow smoke, keep that in mind.
Josh
Old May 11, 2014 | 12:58 PM
  #37
04badford's Avatar
04badford
I Think of Sales reps like Dodges, loud and smokie
Old May 13, 2014 | 12:04 AM
  #38
Super Duty Service's Avatar
Super Duty Service
Former Vendor
Originally Posted by Josh Baker
I thought the Hpop on the 03 and 04 (even late 04) was the same and then they changed the Hpop to the one with the STC fitting on the 05's....
My late 4 has had the problematic HPOP. 2 in 14 months to be exact.
Was the first replacement an oem?? I've replaced many napa hpop's that were only a couple months old. I'd like to hear about how many recent failures people are seeing on recent oem pumps. Everyone and anyone can blow smoke, I can only give my experiences. And my recent oem pump experiences have been good.
Old May 13, 2014 | 07:03 AM
  #39
spinto's Avatar
spinto
I had similar issues. The eventual fail as a "no start" identified the HPOP. The truck is a 2005 but the motor is a 2004, so the prob pump style. I wish i had the time and space to do the re&re myself, unfortunatly i don't. The shop has fixed the truck and i should get it today. While we were in there we replace the ICP and the IPR along with the pump. I don't know whose pump they put in but i will find out the warranty they provide.
IF....you were to buy another pump that has the issues FIXED.....what would you buy. I'd like to have one in reserve.
Old May 13, 2014 | 07:13 AM
  #40
mahdeys's Avatar
mahdeys
What are you oil pressures. Shutting off while hot is almost ALWAYS a HPO problem.
Old May 13, 2014 | 02:21 PM
  #41
mlytc's Avatar
mlytc
Wouldn't hurt to check your oil and see if there is any diesel in it. Mine was doing the same thing and we found that some injectors were allowing fuel to seep into the oil and after the truck got up to normal operating temps, it would just shut down. Let it cool for a while and it would go again. The further into an oil change I got, the more often it happened as the diesel was becoming more concentrated in the oil. 8 new injectors (it was at 200k) and things were good to go until the Black Onyx HG's began to fail on me.
Old May 14, 2014 | 06:18 AM
  #42
Josh Baker's Avatar
Josh Baker
yes both my Hpop's came from the same ford dealership here in the denver area
Old May 14, 2014 | 08:36 PM
  #43
ngwa300's Avatar
ngwa300
The 03s don't have stc fittings or dummy plugs and have different stand pipes. I would air test your system. The fitting is like 20$, but I hear it's really hard to get to the icp (where you put the air in) sensor on those. I also know the 03s are somewhat less prone to high pressure oil leaks. So You can get the tools to test your hpop which is around 60$ I think and easier to get too. I would guess it's the hpop. Id start there.
RedDevil460
Aug 12, 2016 06:07 AM
50belowzero
Oct 28, 2010 09:43 AM
team5150
Aug 14, 2010 02:40 PM
whitestang161
Dec 6, 2009 09:30 PM
RobbieDean
1997 - 2003 F150
May 31, 2007 05:45 PM
