the Ex is dead...
Old May 2, 2014 | 10:04 AM
3cv's Avatar
3cv
the Ex is dead...
Went out this morning, fired right up, then banging noise and a slapping feeling internal to the engine, oily smell, and dead. I fear the worst.
Can one transplant a newer version v10 into these things or is it time to start parting it out and shopping for a new one?
Old May 2, 2014 | 11:13 AM
Bigpipes 35's Avatar
Bigpipes 35
Any year 2V V10 will work but depending what it comes out of you might have to swap over a few things from your V10 like the intake and exhaust manifolds and your accessory's..
Old May 2, 2014 | 11:21 AM
3cv's Avatar
3cv
I just talked to the Ford service down the road, should only be a few grand more than I paid for it if it needs a new engine sounds like...
I was just telling the wife the other day how no one makes such a beast anymore, guess I jinxed it.
Old May 2, 2014 | 11:25 AM
Bigpipes 35
I would do a little trouble shooting before you confirm its the engine, How long did it run before it died, Does the engine turn over or is it locked. I would remove the belt and see if it will crank over as well. that will rule out a accessory freezing up..
Old May 2, 2014 | 11:28 AM
3cv's Avatar
3cv
It fired up immediately like usual, then choked and sputtered back to a stop in about 3 seconds with a jolting/slapping/ sound, and I smelled oily smoke kinda smell. No cloud of smoke though.
If an accessory froze up, it could have been the belt burning... I'll see what it does without the belt...
Old May 2, 2014 | 11:31 AM
Bigpipes 35
Cool, keep us posted..
Old May 2, 2014 | 11:45 AM
3cv's Avatar
3cv
same horrible noise and prompt death... thanks for the idea
Old May 2, 2014 | 12:25 PM
Bigpipes 35
How long did it run this morning before it quit also how long did it run after you removed the belt before it quit..
Old May 2, 2014 | 12:26 PM
3cv's Avatar
3cv
few seconds if that, with or without the belt.
Old May 2, 2014 | 12:41 PM
Elliot Ness's Avatar
Elliot Ness
Fuel Filter Clogged...
Good sign it runs for a few seconds.
A clogged filter may give a few seconds of running and then starvation and shutoff.
Also check the TPS.
Report back and lets get you fixed up...
Old May 2, 2014 | 12:44 PM
3cv's Avatar
3cv
I'm not sure I'm using "running" right. It never really runs without the slaping noise and sputtering to death a second or maybe two later.
No check engine light, no codes scangauge can find.
Old May 2, 2014 | 12:51 PM
3cv's Avatar
3cv
i propped my phone up and video'd it , sounded different from the video than from inside. i spit a plug.. pic in a min
Old May 2, 2014 | 01:05 PM
3cv's Avatar
3cv
uploading the pic is failing. Ive got a cop with a broken mounting tab, boot on the cop, plug in the boot, laying on top of my engine now. It was pushed up an inch or so, i just pulled it out once I saw it.
It is the 3rd back from the front of the engine, passenger side. The hold is slanted towards the front and I can't see the bottom with a flashlight.
Better than insides exploding, but still ug.
Old May 2, 2014 | 01:11 PM
tims01's Avatar
tims01
go find a used motor for cheap on craigslist .. buy it and stuff it in thats what i did .. total cost was $700 including fluids see the van thread for my writeup
Old May 2, 2014 | 01:14 PM
3cv's Avatar
3cv
I've moved 10 hours away from tools, feel so exposed
I'm gonna send it over to the shop and see what they say. If the hole was straight down I could see it and do a timesert or whatever the preferred way to deal with this is, but the angle has me stumped. Shop probably has a scope I'm guessing.
