Virginia Chapter Join Chapter, Leader:
VA May (Spring) is here BS thread
Old May 15, 2014 | 11:21 PM
  #586
Sparky83's Avatar
Sparky83
Originally Posted by Matthew Anaya
might look into it, budget tight right now so new/used is what I might end up doing, last limited slip I had all the spider gears teeth broke so you can imagine how fun that was driving home, so much metal in the rear end, got a lot of looks that day from the noise.
probably about what it sounds like when my f350 stripped the teeth off the ring and pinion gears lol
post 585 has some videos to watch...
Old May 15, 2014 | 11:22 PM
  #587
Sparky83's Avatar
Sparky83
Originally Posted by archtaan
The seal is pretty easy to replace if you have the puller and race.
its not the pinion seal.. its the grease in the slip yoke breaking down and liquifying... which is then running out from under the boot..
Old May 15, 2014 | 11:24 PM
  #588
archtaan's Avatar
archtaan
Needs more lockers.
Old May 15, 2014 | 11:30 PM
  #589
Sparky83's Avatar
Sparky83
they needed cameras on both sides to show how and when the tires spun differently on the red one compared to the black...
Old May 15, 2014 | 11:37 PM
  #590
Matthew Anaya's Avatar
Matthew Anaya
Thats interesting how that works, reliable
Old May 15, 2014 | 11:42 PM
  #591
Matthew Anaya
Looking at around 500$
Old May 15, 2014 | 11:45 PM
  #592
Sparky83's Avatar
Sparky83
gear to gears nice but little noisier too.. since during those uneven conditions you can hear the gears "clicking" when they bind/mesh...
  #593
archtaan's Avatar
archtaan
If your limited slip starts to overspeed one tire, you can apply the brake gently while still applying the throttle and the limited slip will re-engage.
Old May 15, 2014 | 11:47 PM
  #594
Sparky83's Avatar
Sparky83
dont know how true it is.. but have heard with limited slips your only putting about 80% of the power/tq to the ground due to the loss between the friction plates.. where with the gears in the lockers your putting 100% to the ground since the gears cant slip against each other.
Old May 15, 2014 | 11:49 PM
  #595
Matthew Anaya
Bind and mesh, will they wear quickly, constant diff fluid flush, not that I dont love the smell of diff fluid but dont fancy having to seal the cover on and wait for the silicone to dry.
Old May 15, 2014 | 11:50 PM
  #596
Matthew Anaya
Stil learning the manual trans, every other truck was automatic, so that might be interesting.
Old May 15, 2014 | 11:54 PM
  #597
Sparky83's Avatar
Sparky83
cant say on how quickly they wear.. i would assume as long as your not abusing it and kept it well lubed theyd last as long as the ring and pinion does..
im with you not liking the smell of gear oil.. gets in everything for weeks sometimes a few months...
Old May 16, 2014 | 12:06 AM
  #598
Matthew Anaya
Still doing rear end shopping thanks for the info will keep it in mind, the first time I ha e opened the pumpkin cover I made a mess everywhere and after I drained it I pulled the axes out and got a little more diff fluid lovin.
Old May 16, 2014 | 12:10 AM
  #599
archtaan's Avatar
archtaan
Yeah, that could be interesting for sure.
Old May 16, 2014 | 12:14 AM
  #600
Sparky83's Avatar
Sparky83
big drain pain helps control the mess.. easiest thing i found to do was to remove the bottom 3 -5 bolts (depending on bolt count) on the cover, then loosening the others so that the cover stays mainly in place.. that way when you pry the cover up you can have the cover at an angle while most the fluids falling out without the cover falling off.. after the large mass is out i remove the rest of the bolts then the cover....
cant do much about the splash from the axle shafts when theyre pulled..
