Neutral Safety Switch
Old Apr 28, 2014 | 10:48 PM
wlittle's Avatar
wlittle
Help! Anything that is electrical scares the #### out of me but I am in the final stretch of getting my truck back on the road. I had to switch out the steering colum so now I need to hook up the neutral safety wires. I have 2 blue and red wires and 2 black in red wires coming out of the colum and from behind the dash. Does it matter which red/blue goes to the other red/blues and the same with the black/reds? I hope this makes sense to someone as I am sure I made it more confusing than it actually is. Thanks.
Old Apr 29, 2014 | 07:29 AM
fmc400's Avatar
fmc400
MSEE
The connector coming from the truck will have two RED with BLUE stripe wires. Those will need to go to the two matching RED with BLUE stripe wires on the switch. The order of the two RED with BLUE stripe wires does not matter. These are just the cutoff for the neutral safety portion of the combo switch.
The connector coming from the truck should also have a BLACK with RED stripe wire and a WHITE with PURPLE stripe wire. There shouldn't be two of the same color, unless I'm missing something. BLACK with RED stripe runs to the backup lights and WHITE with PURPLE stripe is power. All the switch does is connect those two terminals, so the order doesn't matter - but I'm hesitant to sign off 100% on what you're asking since the colors you're describing don't sound right, and I'm concerned you're looking at the wrong thing.
Old Apr 29, 2014 | 07:33 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1973/77 F100/350: NSS located on steering column, same switch used 1967/77 with all A/T's.
1978/79 F100/350: NSS located on transmission. C4 uses a different NSS than C6.
Old Apr 29, 2014 | 07:53 AM
wlittle's Avatar
wlittle
Thanks guys. I will check again but I am positive that there are 2 black/reds coming from the same bundle and 2 black/reds from the steering colum. This is a 1977 f-150 custom 2w if that matters any.
Old Sep 11, 2014 | 01:57 PM
jbancroft's Avatar
jbancroft
If its any help, my 76 F250, auto tran has the same- 2 red/blue stripe and 2 black/red stripe. When I tape the black ones together, the backup light comes on.
Old Sep 11, 2014 | 02:58 PM
fmc400's Avatar
fmc400
MSEE
Already answered this last spring.
Ordnance
Sep 12, 2014 07:28 AM
okie#1
Sep 28, 2013 10:20 PM
just1me
Oct 10, 2005 01:57 PM
jdftcb
Jun 15, 2004 07:33 PM
TryMe
Electrical Systems/Wiring
Jan 5, 2003 10:37 AM
