converted from auto to manual transmission during frame off on a 79 highboy, is there a conversion kit for the electrical system?? how do you bypass it to start. thanks
Trace the wires back to to engine compartment and you will find where they are plugged in. Ford made a plug that went in there in place of the wires that go to the switch . So make yourself a jumper wire to get the wires tied together. Or just cut them and connect them together. I don't remember the color they are but somebody will know .
Jim is spot on. All you need to do is jump the two RED with BLUE stripe wires together. The other two wires should actually be WHITE with PURPLE stripe and BLACK with RED stripe; they're for the reverse lights. You'll need to change that for the manual transmission too. WHITE with PURPLE stripe is fused hot-in-RUN power to the switch; BLACK with RED stripe is the switched signal that goes out to the lights themselves.
I guess I will need to hook up reverse lights, surely the transmission has a switch on it?? have not spent much time on that end yet, trying to get everything inside fixed first. thanks a bunch for the info.
I would love to have this truck finished soon!! I need to get on to other projects but this one is a real pain! haha. thanks again
