Electronic shift lock
Old Apr 28, 2014 | 08:54 PM
Cobr17's Avatar
Cobr17
Drove my 96 f150 truck parked it went to get in it shortly after and my shifter won't come out of park abs lights flashing as well is it a combined? And is the shift problem a fuse our wiring our what? I can by pass it by turning the key one click and put it in neutral but what's wrong with the shift lock?
Old Apr 28, 2014 | 10:27 PM
UNTAMND's Avatar
UNTAMND
Under the dash is a solenoid. Unhook it and it won't lock the shifter with key on.
It's attached under there somewhere. You'll see it.
Old Apr 29, 2014 | 12:02 AM
Cobr17's Avatar
Cobr17
Is that just gonna unhook it or fix it? Lol will any light come up after
Old Apr 29, 2014 | 01:20 AM
UNTAMND's Avatar
UNTAMND
The problem will still be there, but you'll be able to get it out of park without hassle.
As far as abs light, probably need to get it scanned. I don't recall a self diagnostic for that. But if your 96 is obd2, and may be combined with the ecu codes. Not sure.
Old Apr 29, 2014 | 02:30 PM
Cobr17's Avatar
Cobr17
Ok thanks a lot
Old May 1, 2014 | 03:43 PM
MFJ's Avatar
MFJ
Could also be the brake switch malfunctioning, the one attached to the pedal that turns the brake lights on. It also hooks into other systems. Something to check out.
Old May 1, 2014 | 04:07 PM
UNTAMND's Avatar
UNTAMND
I thought of this a couple of days ago, when my brake light switch wire broke off my mustang. I already unhooked my shift solenoid so I didn't notice the issue. Some guy at a red light run up and told me I had no brake lights, got to work, looked at brake switch and thought , I should post the switch could cause it to not shift out of park... But if your brake lights work, then it's not the issue.
Bertelrud
Mar 27, 2017 04:24 PM
st8yd
1997 - 2003 F150
15
Apr 18, 2013 07:04 AM
mox-ct
Oct 11, 2009 07:50 PM
wizzard351
Offroad & 4x4
Apr 15, 2005 06:57 AM
