Radius arm bushing problem.
Old Apr 27, 2014 | 01:27 PM
Shadow944795's Avatar
Shadow944795
Hello I'm back again with a new problem this time with a set of bushing I got from autozone. I went back to the store today to confirm they were the right ones and they pulled out a box of the exact same ones as they had sold me before doing the bushing. Well for some darn reason when I put everything together when I put the last washer on I just don't have any room left to get the nut on. No matter how hard I try to push them in I just can't get the nut on the thread of the radius arm to squeeze the bushings down and install them. So I'm asking today what order should they go in and what all are possibility as to what may or may not be wrong? And if anyone asks no they have not been replaced during the life of the truck because it still had the old rivets in place to hold the bracket on the frame. Thanks in advance Shadow.
Also the part number for the ones I purchased at autozone is FA7125 if that helps.
Old Apr 27, 2014 | 02:28 PM
Bob Gervais's Avatar
Bob Gervais
Those are the correct bushings. Here's a photo of the order they're installed:
http://broncograveyard.com/images/ad...rmbshngpic.jpg
I've had to use a come along in the past, to pull the radius arm back enough to get the nut on.
Old Apr 27, 2014 | 03:58 PM
Shadow944795
Sounds like a pain in the butt. Any other way to compress them just enough to get the threads start? I'm not against a come along but If I can cheat a little without compromising the bushing I would be very happy. Would shaving one bushing down just a hair be a bad idea? It would not be a huge amount but just enough to get the nut on the threads.
Old Apr 27, 2014 | 04:42 PM
Bob Gervais
Shaving the bushings down would probably not be a good idea.
Old Apr 27, 2014 | 05:57 PM
Shadow944795
I figured so but had to ask. Just to give an update on the situation I put the front bushing and washer on in proper order along with the bracket. I bolt up the bracket and it was going good up until I tried to get more leverage to a get a bolt just a hair tighter and me not thinking pushed on the tire like I did last night to get a bolt free in the first place and ended up pushing it forwards just enough to where I can't get it back in the hole right so I will most likely have to use a come along now and a extra set of hands.
ramick
21
Oct 6, 2013 08:20 PM
67f100
Apr 30, 2006 10:00 AM
MikeGV
Oct 15, 2005 12:29 PM
dale gribble
Sep 10, 2005 12:19 AM
topfisherman
1978 - 1996 Big Bronco
Jun 10, 2004 10:48 PM
