7 Pin Tow Harness Part #?
F6TZ-13A576-BA (replaced F4TZ-13A576-A) .. Trailer Wiring Harness-7 pin connector to trailer, includes bracket / Available from Ford.
Use with Heavy Duty Trailer Tow: 1994/96 F150/350 & F(Super Duty) / 1997 F250/350 & F(Super Duty).
MSRP: $156.47 ~ Dealer net cost: $93.88.
FTE Ford Dealer Parts Dept sponsor online price:
autonationfordwhitebearlake.com: $103.27 / Auto Nation Ford - White Bear Lake MN
silverstatefordparts.com: $110.78 / Gaudin Ford - Las Vegas NV
horizonpartsguy.com: $112.66 / Horizon Ford - Seattle (Tukwila) WA
on
why bother with 20 year old plugs when you can upgrade?
i did this to both trucks.no more adapters from old style 7 round to modern 7 blade style adapters and no more 7 pin to 4 pin adapters.just plug in your commonly used,modern updated style plug of either type your trailer has and go!
both (outdated) oem went happily in the round file.
both oem went happily in the round file.
on
Aside from the three main lighting functions, additional pins for electric brakes, a 12 volt "hot" lead, and backup lights are available. There are two types of 7-way connectors. One has flat pins, which are often referred to as blades. The other has round pins. The round pin style is very rare. The RV style 7-way with flat pins (or blades) is very common. It is often found on newer trucks and SUVs that come equipped from the factory with a trailer hitch.
Trailer Wiring Diagrams | etrailer.com
the ones i took off my '93's were the old and now uncommon/outdated round pin style.i had to use adapters.
if your trailer has the older style,for the love of god,don't let that stop you from updating your truck.simply update the plug on the older trailer too.
this way,you'll be able to rent/borrow/buy newer etc.common trailers without trying to find old style adapter plugs so you can tow that rental/borrowed trailer.
